Question about HP DeskJet F4280 All In One Printer InkJet
Replaced both inks in hpf 4280 but printer is still showing empty and wouldnt print calibration page how do i manuall resent ink levels
    Sergeant:
  • 420 Answers
Slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Posted on Sep 15, 2010
ESP 7250 Not printing the gray color on the test page
Not much to go on. If you mean the black cartridge is not giving any ink, and the printer does not say the cartridge is empty you still have a problem. But it is possible to solve.
If I'm guessing right, remove the cartridge with the black ink and look in the printhead. You see the little pipe sticking up, where the black ink is going in. with a dropper, just do a few drops of cleaning fluid on that pipe and replace the cartridge. Than let the printer print some black pages, till the black ink is coming through.
It also could be the cartridge with the black ink is empty or dried. If you shake (take care you will spray ink if you don't seal the ink outlet) and you don't hear any ink in the cartridge, unless what the computer or printer thinks it still is empty.
Jan 25, 2014 | Cameras
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
My hp 4280 all in one printer says i am out of ink both cart are new.
Good day.
Choose Tools>Print Test Page and check if you still get the same message out of ink. Also check the ink level report on the page which is very important.
If it says out of ink or ink level report shows no ink, check the new ink cartridge and take off the plastic cap off the nozzle.
Reseat the ink cartridges, restart your printer. (Power it off then back off) Check if it's the same issue. If it is,it would also be best to Align the Print head. Setup Menu>Tools>Align Printhead.
Jun 28, 2011 | HP Photosmart C4580 All-in-One InkJet...
Kodak 5300 shows "color ink cartridge needs replacing",even with new cartridge,and new printhead..Ink level display shows color cartridge empty,and its brand new..
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Sep 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Ink shows empty when toner is not even close to empty
there is one thing that if you refill the cartriage and then use again then still ink indicator shows low ink as its' ckt is designed so.
there is no problem you can print easily.
your printer will show correct ink level when you put in new cartriage.
but remember one thing that if your printer stops printing and shows message on computer that no ink in cartriage ,, then you need to reset printer counter, (this resetting process is present in your printer manual)
so no problem in printing, it shows low ink because the circuit inside it is designed soo.
so that you purchase new cartriage.
(remember : you need to reset the counter , refer to manual)
Jul 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Printer level gauge shows cartridges aas empty even when they are
hi,
many times the ink gauge is not true, if u wanna see the actual level of ink, try to print the self test page..........
regards,  raj_p5983
Jan 21, 2009 | HP Photosmart C5280 Printer
Cannot print with new ink cartridge
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Dec 12, 2008 | HP Photosmart C6280 Printer
Excessive Yellow ink use
Issue The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed. Solution Complete the following steps to resolve this issue. Step one: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Replace any empty print cartridges. To access the ink level gauge, follow these steps.
  1. Press Setup .
  2. Press c00707172.gif to select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed. Figure 1: Ink levels c00410056.gif
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
Step two: Calibrate the color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead If the steps above did not help, clean the printhead.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Step four: Contact HP If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
Jan 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP DeskJet F4280 All In One Printer InkJet Logo
377 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
