Question about Sony RDR-GX360 DVD Recorder
I connected dvd to recorder to tv - I get sound but no picture
  • 597 Answers
It simply means there is an error in the connection of the cable to the television.
first ensure that there is a cable plugged to the video out of the dvd then you trace the wire and connect the other end to the vidoe in of the television.
After doing this, your display will come on, on the television.
Try to use new cables, in order for there not to have been a breakage in the old cable you were trying to use.
Take care
Posted on Sep 09, 2010
My LG DVB-T HDD/DVD Recorder will not play or record sound via TV Channels!
If the TV source is separate from the recorder, there has to be a physical connection between the two. From your description it seems there is a video connection, but what about audio?
Dec 03, 2013 | Televison & Video
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Quite simple, I have an LG video recorder, and a Wharfdale dvdr24hd160f, both in line to my TV. Is there any way I can record old family video tapes to DVD, without interfering with my current wiring...
Hi, You should be able to depending on how your DVD is connected up. If it is hooked up using a yellow, red, and white lead (RCA. Common lead with a pin in centre of plug) there it should be no problem. On your TV there should be a set of sockets of the same colour. These should say monitor out, our output. Basically this set of plugs will send the picture and sound of whatever you are watching on the TV. If you connect from your monitor output sockets on your TV, to the input on your DVD recorder (will likely say AV1, or input on your DVD recorder) then it should record your video. You just have to make sure that the picture on your TV is the video you are playing, and the channel that is set to record on your DVD recorder is AV1. (You may also have an input at the front of your DVD recorder that says AV2 or input 2.) As long as you set your DVD to record the input set of sockets you plugged your cable into it should work. This set up will not alter the operation of your DVD or TV.
Oct 26, 2009 | Televison & Video
No picture when I play back on vcr
Are you using AV connections(Red, Yellow, White) cable connections? If so The video connection may have come loose.
Feb 10, 2009 | GoVideo Go Video DVD/VCR Combo
How do I conenct player to tv
  1. Yellow wire is picture and the 2 red is sound
at the dvd player plug in the picture wire by av out, at the tv plug the yellow wire in av in.
The sound is the same sound out at the dvd player look for a L R this means left and right at the tv there should under av in next to the picture wire you pluge the soun in
hope this is clear to you
Jan 04, 2009 | RCA DRC220N DVD Player
New hdtv
First off, scart has an auto detect feature across pin 8, HDMI does not. If you have turn your TV to the HDMI channel, and at some point turn off the HD source device you are going to get a blank screen, you have to manually turn your TV back.
In regard to whilst you are recording it sounds like you may have tuned in channels on your DVD but not your TV.
Do you have an RF aerial lead connected from the DVD output to the RF on you telly?
Do you have a sky/cable box connected to your TV via scart?
Does the DVD have DVB (digital video broadcast) if so and you have none of the above that is the problem, any tuner running off a single RF lead can only record/play 1 channel at a time. If you have no RF lead going to the TV, then the TV cannot show any terrestrial channels.
Jun 15, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Philips DVD player/Recorder which is attached to a Samsung Television and cassette recorder I get a very good picture but no sound. The Phillips recorder is a DVDR 3480
IF it is connected via a scart lead, make sure that the connectors at both ends are pushed in securely to the DVD and TV.
Scart connectors have 21 pins, and the audio pins are at the opposite end to the video pins, so if the connector isn't in straight, you either get sound & no picture or vice versa.
If this isn't the case, give more details on the connection.
May 14, 2008 | Televison & Video
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
Sony RDR-GX360 DVD Recorder Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
