Question about Compaq Computers & Internet
Hello i was wondering if i could use any compact start up disc for any other compaq computers
  • 3 Answers
Depending how old the CD you have is. The way compact made their CDs before was to recognize the workstation/laptops if it's made by compact. But they could've made it a littl emore sofisticated to look for the same model only. If it's the same model, then no issue. If it's not, then the worse thing is it will tell you it is not compatible. Also the drivers for a different model might not be available on that CD, so you would have to download your drivers form the manufacturer of that hardware/component
Posted on Sep 09, 2010
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Hello cannot access into my compact computer....
Actually the procedure is really easy.
You need an installation CD of the Windows version you have installed on your system.
Insert it in your CD ROM, and boot your computer from it.
After a short time (maybe 30 seconds to two minutos) you will be asked to select your language.
Click Continue.
Next screen you'll see a big INSTALL NOW message......
But if you look closely, on the bottom half on the left hand, you'll read among other things, something like "Repair your Computer"
Click there, and after a little while, Windows will find the problem and a message will say:
Windows has found the problem and fix it.
Press the button to accept the suggestion, remove the CD, and your computer will restart all the way to your Desktop.
Hope this helps,
Jun 06, 2011 | Compaq Computers & Internet
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
Computer will not start up. Screen says "setup is
try to restart the pc with the cd intact if that is the case. Normally, it goes towards your desktop icons..
Apr 10, 2011 | Compaq Presario Notebook
PC will not boot up. Almost did once but screen went black. Reboot doesn't help. No green light on monitor and PC makes a long slow beep over and over. I have recovery discs but when put it nothing...
Based on your description of your problem, my educated guess is that you have a problem with the system board or motherboard. Checking Compaq support site, it says that beeps are generally heard when a hardware device is not connected properly or has failed.
First thing to try is disconnect the keybaord and mouse and try to start the computer again. What we are trying to do is find out which hardware device might be involved. So start with the keyboard an mouse. If the computer still does not start, remove any periferal drives, like floppy or cd drives.
There are several beep codes, below are a few examples listed:
Beep codes common to HP and Compaq Desktop PCs The following beep codes are common to many HP and Compaq desktop computers. Use these codes first before referring to the other code lists. NOTE: Not all codes are shown. Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful Try working on this solution and see if you can get the computer to start. Below is a link to a troubleshooting page from Compaq for your computer. This can be a good reference as well.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899280&tmp_task=solveCategory&lc=en&dlc=en&cc=us&dest_page=solveCategory&tool=solveCategory&query=pavilion%20m8200n&product=3548185
I hope that this information was helpful.
Brian
Jan 05, 2011 | HP PAVILION M8200N PC Desktop
What is the usb socket for
Hello
USB mean Universal Serial Bus. There are so many USB devices such as Mouse of computer, Musical USB devices which can store MP3 and videos in it, like we have the Compact Discs and DVD discs. USB connector is meant for connecting such devices to the unit. OK.
Nov 19, 2010 | Televison & Video
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
C.p.u failor
hello, you cd rom drive is faulty thats why it restart your computer any time you insert a compact disc.
Dec 18, 2008 | Intel D915GAV Motherboard
We need to download compact disc
what? compact disc is not virtual you can put it in your hand and carry it... how do you download a compact disc? do you mean transfer files? if so just go into your my computer page and double click your cd drive
Jun 30, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
