Question about GE Dryers
Dryer was not heating replace heating element, how dryer still does not drying looking at wire legend and found two thermal fuses how can i check fuses.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
MY WHIRLPOOL DRYER WONT DRY NO HOT OR WARM AIR
There are usually two reasons for no heat.
1. The element is burned out.
2. The high limit switch or thermal fuse has opened.
This is assuming it is a electric dryer.
If it is gas it is probably an ignitor failure.
To check the thermal fuse unplug the dryer remove back cover look for a small usually plastic looking piece with two wires attached
remove wires and check for continuity between teminals
if open replace.
if there is continuity chances are the element has failed
these can be more difficult to replace depending on model.
recommend contacting a service proffessional.
there is usually a reason for the thermal fuse to fail ( ie high heat)
check venting for obstructions and lint filter.
hope this helps.
Dec 02, 2013 | Dryers
A whirlpool gas dryer will not heat up
If your dryer is not getting any heat, you need to make sure there is nothing blocking the vent. IE: LINT. Air flow is key to efficient drying. Make sure the dryer settings are appropriate for the clothes you want to dry. The timer selection, fabric selection, and the temperature selection all play important roles in proper dryer operation.
Check the heating element, burner operation, ignitor, thermal fuse, and the wiring (power cord).
• Heating element (For Electric Models)
• Burner operation (For Gas Models)
• Ignitor (For Gas Models)
• Thermal fuse
I WOULD START WITH:
To protect from over-heating, many dryers use what's commonly called a thermal fuse. If the thermal fuse gets too hot, it will blow, and completely shut down your dryer until it is replaced. This fuse is often mounted within the exhaust duct in the back panel. It's about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced. When replacing this fuse, check the dryer vents to make sure there is no lint buildup which can cause the heat to stay trapped and blow the fuse again.
Visually inspect your heating element for any broken or burned areas.Check the coil for continuity with a Volt Ohm Meter. If there's no continuity, it means that the element is bad and you need to replace it.
If the ignitor is cycling without the burner lighting, you probably have defective electrical coils in the gas valve. These coils look like black cylinders with wires coming out the top of them, and are located near the burner valve assembly. When they get power, they open up and allow the gas to get through to the burner. If this is a new installation, make sure the gas valve is turned on.
Sep 28, 2013 | Home
Whirlpool dryer isnt drying
USE THE COMMON SENSE, FIX IT. God bless you
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating element is easy to replace. Check our videos for other types of dryer heating elements.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and easy to replace.
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 03, 2012 | Whirlpool Duet WFW9550 Front Load Washer...
Wont dry
Hello there and welcome to fixya
This is a fairly common problem in dryers i will post the possible solutions on what to look for and the things you will need to test ok?
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page. Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Feb 11, 2012 | Whirlpool Dryers
Hello, I have a Kenmore Dryer 90 series... We are in a Town house on and the Dryer is on the 2nd floor and the vent goes up vertical for about 12 ft with a 45 then to the roof... my dryer gives off heat...
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
More than likely it is the heating element.Remove the front lower panel.While the dryer is running look inside at the bottom,if the element is getting hot you will be able to see it.If the element is not hot,replace it.
May 13, 2011 | Dryers
Dryer drum works but does not heat. Everything else works. I have checked the fuse and I have made sure it is not on air dry.
THERMAL FUSES MAY BE THE CAUSE OF THIS In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element. Follow the diagram below to see how to check the continuity of the switch, and look closely at the switch to see a fairly close idea of what you are looking for, ok
OR it could be a thermostat.
Cycle and safety thermostats-read them with an ohm meter. Should show continuity .
or lastly, it might be
the Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
IF you do not have an OHM-METER, then you can check these issues by following the directions below:
Do not forget to rate this answer!!
Jan 24, 2011 | Frigidaire Electric Dryer
No heat
Check the following---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
May 29, 2009 | Whirlpool Dryers
Wont dry
CHECK THE FOLLOWING---
2. Heating element
3. Thermal fuse
May 03, 2009 | Maytag Neptune MDE4000 Electric Dryer
No heat
If there is no heat during drying cycle, it is usually either the heating element, or a thermal fuse.
See the following suggestions from repairclinic:
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Oct 19, 2008 | Splendide 2000S Vented Washer/Dryer
Dryer
When dryer does not heat, or heats too slow, that means that there is a problem either with the heating element, the thermal fuse
Unfortunately the only solution is testing and eventually replacing either the heathing element or the thermal fuse. Both jobs must be performed by a technician.
If you insert model number here you can get replacement parts and exploded view.
See the following suggeations from Repairclinic:
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Checkto see whether there's power getting to the dryer. Is it plugged in?Check for blown fuses or tripped circuit breakers--your dryer uses twofuses or circuit breakers. The dryer could tumble but not heat if onlyone of the two fuses is blown. If you have circuit breakers, one of thetwo circuit breakers can trip, even if the two for the dryer areconnected.
Heating element Oftena dryer heating element burns out, but doesn't trip the circuit breakeror blow a fuse. The heating element is simply a long coil of specialwire. You can check it for continuity with an ohm meter. No continuitymeans the element is bad and you need to replace it--electric heatingelements aren't repairable.
Thermal fuse Onmany dryers, there's a thermal fuse mounted to the exhaust duct insidethe back cover panel. The fuse--which is about an inch long--is usuallyembedded in black resin and mounted in a white plastic housing. If thefuse has blown, you need to replace it. (You can't re-set it.)
Wiring Acommon problem is for the main wiring connection from the house, at thedryer, to burn and break its connection. Because the dryer can stilltumble with partial power, the connection may be only partiallydefective. You may need to replace both the power cord to the dryer andthe terminal block inside the dryer that the wire is attached to.
Oct 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
62 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
