Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
Top freezer and refridgerator not maintaining cooling temps
  • Magic Chef Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Jenairrefridgerator model jcd2292ktb, what is the temperature for freezer and refridgerator
If you want to set the temperature your Fridge/Freezer should maintain, you need to set the Freezer to between -19c and -23c, however if you will be keeping Ice-cream in this freezer then it's best to set the base temp @ -21c minimum, -23 preferable, or the ice cream may begin to break down (very slowly I might add). The Fridge needs to be set to a maximum Highest temp) of 5c, any higher and the food will not stay as fresh and bugs will be able to breed, preferable temp is approximately 3-4c.
Jun 20, 2012 | Refrigerators
The refridgerator and freezer are failing to maintain temperatures. The light for the refridgerator temp. is blinking constantly. Both sides continue to raise in temp. regardless of where the setting is...
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Samsung RS2630SH Side by Side Refrigerator
How should I set the temperature. The refridgerator and freezer is not able to maintain a consistent temperature. What is the correct freezer and top refridgerator setting and how do I know it has accepted...
Basically the thermostat controlls the freezer temperature which turns the compressor on and off.
The refrigerator section receives cold air from the freezer to cool it down.
So when the freezer is off there may not be enough cold air left for the refrigerator.
Fridges can never give you a perfect temperature every time there will always be a drift one way or another.
Once you reset the temperature the numbers or an led should blink at you to confirm the changes you made
Mar 25, 2011 | Liebherr KGK 2833 Comfort Bottom Freezer...
We have a 2 door LG refreidgerator.(2 years) We can see the freezer is cooling but nor cool air coming into the refridgerator compartment what would be the problem.
Hi!!
Check your temp. settings, Sometimes we move the controls by accident. Also check the fan in the freezer, make sure it is woriking properly, this fan is the one that blows cool air into fridge compartment.
Good Luck!!
Mar 13, 2010 | Frigidaire FRT21S6A Top Freezer...
Freezer and refridgerator are not maintaining cold temp. Compressor is Hot?? what can i do.unit is less than 3yrs old
Try cleaning condenser. Also check if there is a condenser fan and if so is it operating properly.
Good Luck,
Gilsh
Nov 26, 2009 | Kenmore 64802 Top Freezer Refrigerator
The top refridgerator is not cooling correctly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
fgmjfd
Sep 29, 2009 | Samsung RB1955VQ Bottom Freezer...
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Refridgerator not cooling but freezer works
check to see if freezer has ice on it if so it is going to be the automatic defrost system
May 02, 2009 | Refrigerators
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
50 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
