Question about Daisy Toys
I have a 2002 35 shot repeater. My problem is that the 35 shot repeater clip does not work. not sure if its just getting jammed or if it isn't operating properly. i am using the right size pellet (.177) so it should not be jamming. Is this just a bad design or what? is there a way to fix it?
    Problem Solver:
  • 8 Answers
Are you sure that it is the clip and not the catch feeder below it alot of times one side of the feeder on the bottom will break causing it not to load properly. You should be able to feel it and see if it is loose,
Posted on Sep 30, 2010
Are you using a flat nosed pellet? The round and pointed pellets will jam ihe mag every time.
Posted on Jun 26, 2013
Can not get rile mag to feed cartridge. marlin 99c using a marlin self loader 10 shot. Bottoms out before the chamber
have a close look at your clip to be sure nothing has bent look for any wear marks to see if action hitting clip has this clip worked well before make sure gun is clean with no oil just some wd40 also if your using shorts they probaly dont have the power to work good
Feb 04, 2017 | The Optics
My 308 winchester semi automatic rifle jams after shooting first bullet. In order to recover, you remove the clip, eject the bullet, replace the clip, **** the rifle and shoot second shot jams
no
there is a small lip that pulls the shell out of the breach as the bolt moves back
take it in to a firearm repair shop and have it properly fixed
Oct 05, 2016 | The Optics
Pull cord jammed in the lawnmower
There could be several reasons for this problem, but sometimes it is in need of a simple cleaning. Remove the 3-4 nuts holding the starter assembly on the top of the engine. Normally you will use a 10mm socket and ratchet to remove them. Turn the starter over in your hand so that you are looking at the starter pulley. Inspect the starter rope and make sure it isn't jammed between the starter pulley and the housing. If it is jammed, grab the starter rope and starter pulley and rotate them both together clockwise until the rope becomes unjammed. If the rope isn't jammed, turn the starter pulley counter clockwise gently. It will probably spring back and draw in the rope. If it retracts the rope slowly, spray WD40 around the bolt in the center of the pulley and work the pulley back and forth until the pulley frees up. If it doesn't free up or this isn't the problem, get back with me and I'll try and walk you through the rest of the repair.
Sep 13, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Cd jammed won,t eject
Hi.
Try pressing repeatedly the eject button on the on dash player while turning on the stereo at the same time. If that does not work disconnect battery terminal for one minute to reset the electrics and try again pressing eject repeatedly on startup. Make sure that you have the stereo anti theft code if needed before disconnecting the battery.
If that does not work, then the unit must be disassembled. The car stereo must be removed from the dash. The unit must be disassembled removing screws at back and bottom and undoing metal casing clips. That will reveal the CD drive allowing to remove the disk.
Regards.
Ginko
Sep 14, 2011 | 2006 Pontiac G6
No visible leaks in cooling system but engine overheats. 2004 Ford Explorer 4.0L V6. Fan working fine. Any suggestions.
#1.airlock in system....undo a heater hose clip to bleed.#2 thermostat jammed..replace.#3..water pump shot..replace.#4..radiator clogged..backward flush the system..
Oct 15, 2010 | 2004 Ford Explorer
Stapler jams repeatably, chrome housing separating.
This is not the company that made it. The site you have is a site where people mostly volunteer their knowledge to try to help others. As for your power shot contact Black and Decker they make it and from what you've described you have a defective stapler.
Jun 10, 2010 | Powershot Tool Company Cobra 8000 Forward...
My daisy buck 400 shot repeater bb gun wont shoot
bazthespazz i would like that file you said, just bought the daisy buck 400 and got jammed arround the first 20 shots nd i want to repair it but its hard to remove the piece of the trigger
Jul 30, 2009 | Toys
I took apart my 66 powermaster bb gun and i cant put it back together? can u give me a diagram of picture
C66-OM
C66-EVP & PL 1 & 2
Powermaster. Pneumatic, BB repeater, .177 cal., single shot pellet. First variant w/zinc receiver. 1983-1988 Some parts are available. 66 pdficon.gif
C66-OM
C66-EVP
Powermaster. Pneumatic, BB repeater, .177 cal., single shot pellet. Plastic receiver. 1988-2001 Some parts are available. 66 pdficon.gif
C66CLIP-OM
C66CLIP-EVP
Powermaster. Pneumatic, BB repeater, .177 cal., single shot pellet. Plastic receiver and 5 shot manual clip. 2001-Present Some parts are available
HERE IS MANUALS I FOUND..HOPE THIS HELPS..
Apr 11, 2009 | Crosman (4032)
Mosberg 22 lr plinkster jaming
Give it a good cleaning the extractor that catches the edge of the shell casing to pull it from the Chamber my not be working due to powder residue.
Apr 04, 2009 | Sport & Outdoor - Others
The videos recorded on the camera seem to repeat over and over without finishing the entire clip
What Windows you are using in your computer like Windows XP or Vista?
Please check driver updates for your camera at Sony Support.
Sep 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Toys Logo
601 people viewed this question
Top Daisy Toys Experts
Tom Chichester
richie46
Are you a Daisy Toy Expert? Answer questions, earn points and help others
