Question about ASUS P5GPL Motherboard
My motherboard Asus P5GPL doesn't turn on. Not even the Green Led light on the motherboard turns on. I know that the power supply does work . What could be the problem?
  • ASUS Master
  • 11,800 Answers
Replace the memory and try again - if it's the same then replace the cpu and try again. If even now it doesn't work then it's dead, replace it.
Posted on Sep 09, 2010
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
Serious problems with an Asus M2N E SLI motherboard.
have you tried removing all other hardware like your graphics card and all other peripheral cards even memory and booting to see and eliminate all other components?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
How many watts power supply is best for my asus p5gpl
this really depend what you are going to use with the motherboard with just standard video card and I/O cards and 1-2 hard drive than 300 to 500 watts would be okay
but if your a gamer or internet junkie than 600 watts and above
here are some information you need to look for or at.
www.tomshardware.com/forum/292327-28-best-power-supply-brand
Jan 07, 2011 | ASUS P5GPL Motherboard
Green led power light comes on then power goes off and comes back on repeatedly. It never posts.
Your motherboard was manufactured in late 2009. The green LED on the MB supplies DC power to the BIOS. This is known as standby. This is a relay is built into the MB maintaining the required 3 volt. When you power up the MB the power supply maintains the
3 volt DC to the BIOS. So the relay is not working. Suggest you contact Asus. All Asus MB's carry a three year warranty. Your board will need to be replaced by Asus. Call Asus at; 1-812-282-2787. (Asus Tech IL EST) M-F 8:00 to 5:00PM) There is a sticker on the LPT printer port. Write down the serial number, you'll need this when you make the call.
Mike
Jul 27, 2010 | ASUS P7P55D PRO Motherboard
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
First Hello. Before few days,when I turn on my PC(but I was unpluged my machine from electricity) and on monitor displays CMOS wrong set date/time,cpu frequensy.I hit BIOS set up sittings and Windows xp...
Replacing the bios battery was the correct thing to do. Answer me this. The Asus motherboard should have a green LED light lit (Standby power LED), when the system is turned off. Also keep the power cord for the power supply connected at all times. Though it is possible the replacment bios battery was all ready low on voltage or dead. When you're system is turned off the power supply continues to send 5volt DC to the motherboard which maintains the bios 3volt DC.
If the green LED is not lit than there is no power charging the bios battery and every time you boot the system the bios will have lost its settings. If the green LED is red in color, than the problem is within the standby switch built into the motherboard. The standby circuit can not be repaired. Double check all power connectors from the power supply to the motherboard. If everything has a good connection and you're bios settings continue to reset you should consider replacing the motherboard. At this point you have nothing to loose. Install the latest bios update,
(Beta Version 1010.005). 2006/02/14 update.
http://www.asus.com/product.aspx?P_ID=d2Gi3Hr6quXOk51C&content=download
Mike
Jan 23, 2010 | ASUS A7V880 Motherboard
My motherboard Asus P4B533 doesn't turn on not even the Green Led ligth on the motherboard turns on. What could be the problem?
hi, 3 points:has the fuse in the plug gone,or the power supply is blown or lastly the motherboard has blown.Contact chris at 07926-106150 or on http://www.motherboardsrus.net
Jun 08, 2009 | ASUS P4B533-VM Motherboard
ASUS P5GPL Motherboard Logo
83 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
