Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Why is my thread always doing birdnest and going oround my feeder and breaking my needle
    Genius:
  • 1,788 Answers
It sounds like you do not have it threaded right, completely rethread it and make sure that you have a fresh needle in the machine. Reread your manual, I am sure that something is wrong in the top threading. If, you misplaced your manual go to singerco.com and download it for free.
Posted on Sep 09, 2010
HOW DO I OIL A VIKING DESIGNER SE EMBROIDERY MACHINE, TRYING TO FIX THE PROBLEM OF BIRD NESTING.
bird nesting is from needle thread tension being too loose
increase the tension up
May 02, 2017 | Sewing Machines
Pfaff Creative 2 loops on underside of fabric
Although there could be several reasons, this is generally called bird nesting or thread nesting. It is usually a result of loose upper tension, mis-threading, or possibly a needle/thread/fabric incompatibility.
#1--when you thread, make sure you ALWAYS raise the presser foot so the thread seats in the tension disk. And, be sure to change the needle often...
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
https://lindeegembroidery.com/common-causes-of-birdnests
Nov 12, 2016 | PfaFF Sewing Machines
Fixing the problem of birdnesting
Birdnesting is a common but very frustrating problem that can be resolved easily once you know where the problem originates. Remember, if the birdnesting occurs on the underside of the fabric, the problem originates with the upper thread. If it shows on the top of the fabric, the problem is the bobbin.
Very often, the machine is not threaded correctly. Remove all the thread from the machine. Check there are no loose threads or lint stuck anywhere in the machine. Oil as instructed in the manual.
Install a brand new needle! The needle should be suitable for the thread and fabric you are using. All About Needles
ALWAYS RAISE the presser foot and rethread the upper thread. Verify the path is correct.
Check that the bobbin is installed and threaded properly.
Pull the bobbin thread to the top of the fabric.
How and Why to Bring up the Bobbin Thread
Set the upper tension to the midway point.
While holding both thread tails lightly in your left hand, begin sewing slowly.
sewing machine birdnesting Google Search
Oct 27, 2016 | Sewing Machines
The thread keeps breaking .
You may have the tension set too tight or are not using the correct needle. Or, the bobbin thread may not be the same as the top thread. If the tensions are o.k., try using a ballpoint needle.
Dec 23, 2015 | Sewing Machines
Birdnesting with every size needle and thread
tension is not set properly .possibly both upper and bobbin
Dec 14, 2015 | Sewing Machines
The thread gets caught up in bobbin area
This mess is commonly referred to as a bird's nest or 'birdnesting' and it's usually caused by incorrect top tension and that's often caused by the top thread not in the correct path. (For me, I occasionally forget to thread through the take-up lever.) A damaged needle can also cause birdnesting.
Aug 02, 2014 | Husqvarna Huskystar 207 Sewing Machine
Find free manual for white japanese sewing machine model #1010
check this link & see if it's the manual you need
http://www.singerco.com/uploads/download/738_white-445,988,999,1010-x.pdf
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
the feeder bar, do you mean the feeddogs, that are in the needle
plate?
for the feeddog part try sew4less.com
Aug 14, 2012 | White Sewing Sewing Machines
New home model 4018 birdnesting problem help
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
check to make sure the thread has not come off the thread take
up lever
Aug 05, 2012 | New Home Sewing Machines
Singer 5430C bobbins thread always loopy
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Feb 15, 2010 | Singer 5050 Mechanical Sewing Machine
The top thread keep breaking. should the tension
Thread breakage is usually due to the needle in backwards, upper tension too tight or old/weak thread.
When replacing the needle, make sure that the flat side is to the right (3 o'clock position) and is pushed all of the way up before tightening.
What brand and weight of thread are you using and are you sewing with the foot or free motion sewing?
Jun 17, 2009 | Juki TL-98Q
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
65 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
