Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
DD603 gives me an F3 and stops before wash ends, then beeps.
  • 205 Answers
Hi- The F3 fault is related to the water temperature. Probable cause is the controller not sensing the correct water temp. It is also possible the the heater plate is faulty. Hope this helps.
Posted on Sep 24, 2010
Dd603 stops mid cycle with no beeps or alarms
Please check if this happens with the short rinse cycle as well.
Also when the fast cycle stops, check if the water is cold at room temperature. Normally water temperature for wash cycles should be at leat 40deg C.
May 04, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
F3 code and beeping noise
Not sure which model number dishwasher you have. But usually F3 error means a water temperature related fault. The water temperature is too high. Hopefully you are not using the hot water supply of your house. If so then ensure it is less than 80 deg C. If using normal mains supply (cold water) then it is likely the temperature sensor in dishwasher has failed. Not an easy job to fix as it is integrated into the water heater element at the base of the drawer for the DD603 drawer type dishwasher.
Mar 19, 2013 | Fisher and Paykel Dishwashers
Dd603 has F3 and spanner on display and it beeps
F3 Water temperature sensed at greater than 85°C ( 185°F)
1 Is the incoming water temperature greater than 85°C (185°F)
Y: Adjust the incoming water temperature.
N: Go to Question 2
2 Is the element on all the time?
Y: Replace the electronic controller
N: Go to Question 3
3 Are the wiring and connections from the controller to the element all okay?
Y: Go to Question 4
N: Repair or replace wiring harness or wiring connections
4 Are there any signs of moisture around the temperature sensor?
Y: Locate and repair source of leak
N: Go to Question 5
5 Is the resistance of the temperature sensor correct?
Y: Go to Question 6
N: Replace heater plate assembly
6 Does the machine fault again if run through a test cycle?
Y: Go to Question 1
N: No fault found
http://www.appliancerepairlesson.com
Mar 04, 2011 | Fisher and Paykel 23 in. DD603H SS...
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Hi
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
Fill Fault appears during wash cycle.
Is the filter in the hose where it screws onto the tap clean?, if this is okay then most likely the valve.
Apr 19, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Control panel or electrical panel not working right. It stops washing at 10 minutes
The DD603 dishwasher from Fisher and Paykel is a very sofisticated electronically controlled dishwasher. It does not have a control panel or electrical panel unlike some of the other brands of dishwasher which are electromechanical controlled.
So if it is stopping with 10 minutes left on the LCD display, then it might have simply gone into the Dry mode. A small fan in the door unit starts up and sends warm air into the unit. At this time the dishwasher gives a couple of beeps. You will have to wait until the time display goes to 00 provided the dishwahser is set to be in the Clean Dish indicator option is on. This means the washing is complete. Refer your instruction manual.
It is also a good practice to keep the area around thw wash program button (on the drawer door top edge) clean. Sometime grime can cause false trips.
Hope things are not as bad as it may appear.
Nov 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I tried cleaning the oven and got the error F3.
Electronic control has detected a fault condition. Push CANCEL pad to clear the
display and stop the display from beeping. Reprogram the oven. If a fault reoccurs,
record the fault number.
Jul 13, 2009 | Electrolux Kitchen Ranges
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
216 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
