Question about Panasonic HDC-SX5 DVD Camcorder
In my panasonic hdc- SX5 - when turn it on...control data error has been detected its the first that I see on the screen, can´t shoot , second sign ... cannot repair control due to a low battery power ... but I have no problem with the battery its. new .. I think it´s a software problem, please help me, thanks sebastian
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: product HDC-SX5
The original battery it is supposed to work for a longer time.
If it works only for twenty minutes, and you recently bought the camera you should contact the seller and ask a replacement for the camera.
Posted on Aug 28, 2008
  • 4 Answers
SOURCE: CD Software for Panasonic NVGS-180
Go to this side and upgrade til vers. 6.0
http://panasonic.jp/support/global/cs/soft/download/motionDV60E_LE_1.html
Follow the instructions very carefully.
Best Regards
Christian, Copenhagen, Denmark
Posted on Mar 16, 2009
Rexdreamer
  • 76 Answers
SOURCE: Get "DEW DETECTED" warning on screen, powers off.
Also try this, take the bottom cabinet off, with the lcd panel facing you and the camera turned upside down and the cassette housing pointing away from you you will see 2 wide gold cables plugged into the right side of the board, realitively the same size, the gold cable that is between the main pcb and the mechanism assy is the control cable pull it our of the connector and clean it with alcohol, you can even take it one step further and evenly trim just a hair of the cable off all the way across just so that it has a new place to set. This has worked for me over 100 times in the past years. Seasoned camcorder technician 13 years experience.
chrisveal@msn.com
Posted on Apr 22, 2010
Panasonic hdc mdh1
My camera mdh1 Error occurred Problum Solution
Sep 25, 2013 | Panasonic Hdc-mdh1 Hd Camcorder pal Mdh-11...
HDC - SD5 Software Won't Install On Win XP SP 3
I will try to look for the software for that..
micro
Jun 07, 2008 | Panasonic HDC-SX5 DVD Camcorder
I just got my Panasonic HDC-SD80 in the post. I am charging it but tried to turn it on just for a quick look. The camera turned on and I could scroll through the menus on the touch screen and stuff but...
sometimes this happens if there is a fault with the memory card. switch the camera off, take the battery and memory card out, leave it for 2 mins, put the battery in (DO NOT PUT THE MEMORY CARD BACK IN) wait for the message on screen saying no memory card detected. switch off camera, put memory card in, switch on the camera, this normally cures the blank lcd screen issue
Aug 22, 2011 | Panasonic HDC-SD80 Camcorder
Panasonic HDC-SX5 DVD Camcorder I am getting only got a blank screen, it appears that the LCD/Viewer does not work anymore. How can I fix it? any suggestion? thank you
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to usually be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 14, 2010 | Panasonic HDC-SX5 DVD Camcorder
Error Message
try to format the sd card from the camera and then check if it is usable,if not try another sd card.
Oct 11, 2009 | Panasonic HDC-SX5 DVD Camcorder
Product HDC-SX5
Aug 28, 2008 | Panasonic Video Cameras
Problem with HD writer 2.0E
The reason for this error is that there is a conflict between HD Writer and other software on your computer. I was trying to find a solution for weeks before Panasonic advised me to remove other DVD burning software on my computer. I therefore removed Pinnacle and DVD decrypter (which I believe was causing the problem), reinstalled HD Writer and then everything worked fine. Note however that the DVD-RW discs I had tried to use before were corrupted and couldn't be reformatted and therefore once you have removed the other software and reinstalled HD Writer, start again with new DVD-RW discs. Good Luck.
Jul 23, 2008 | Panasonic HDC-SX5 DVD Camcorder
Hd writer 2.0E fro sx/sd
I had this same issue...I bet you're using DVD-R, am I correct?
Apparently you can't copy video from DVD-R to the HD Writer. Period. Just can't do it. (Would be nice if they mentioned this in the manual.)
You can only use DVD-RW and must format the disc to VR format, not Video format.
I'm using a program called Handbrake (free) which I think can convert your .vob files (from the Video_TS folder on your DVD) to quicktime files, or similar, so that you can actually do something with the video...
Best of luck, I'm really no expert, and I probably won't return to this page, so a reply to me is likely not going to be read by me...
Feb 07, 2008 | Panasonic HDC-SX5 DVD Camcorder
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Panasonic HDC-SX5 DVD Camcorder Logo
246 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
