Question about Cycling
Old schwinn 10 speed rear wheel removal how - Cycling
    Genius:
  • 1,788 Answers
Release rear brake, either will have a lever on brake assembly or remove a brake shoe, shift to the smallest gear in rear, then loosen with a #15 metric box wrench, then push the wheel out. All bikes are metric, not just Schwinn. Then reverse to reinstall.
Posted on Sep 13, 2010
How do I change the inner tube on my rear tire
This is no easy task!
You will need to remove the rear wheel to access the wheel, tire, and inner tube
Unless you have a single speed rear axle, you will be needing to disconnect the multi-speed gearing, which you may not really enjoy.
God bless your efforts.
Apr 19, 2016 | Schwinn 24in Riverside Girls Cruiser Bike...
Removal of rear wheel gear on a 1972 suburban 10 speed
You can replace the spokes,without removing gears,by deflating,and removing tire. Each spoke will(should be held in by a machine screw. Detach from the rim,and slide out through holes in gear assembly. You would have to replace the spokes 1(or 2)@ a time;which admittedly,is a tedious process,but this should work. Peace. God bless.
Dec 16, 2013 | Schwinn Cycling
Removal of rear wheel with internal geared 3-speed and coaster brake hub
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Feb 24, 2012 | Cycling
Chain slips like it was trying to come off
If this is a seven speed Schwinn bicycle, you may be able to adjust the rear wheel (loosen the mounting nuts and slide the wheel rearward) or you may have a "stretched" chain and will need to remove a link (not an easy task without a chain breaker), hope this answers your question.
Dec 14, 2011 | Garden
I have a Schwinn 7 speed deluxe cruiser. When I pedal, it feels like the chain is skipping a tooth on a sprocket. Is it worn, broken or an adjustment needed? There is no derailur on this old classic,...
You have conflicting info. If there are multiple gears then there is a derailer. You should take to a bike shop where they can look at it. It is probably a very small easy adjustment.
Jul 25, 2011 | Schwinn Cycling
I have an old schwinn varsity. I went to change the rear tire, and turned out the rear axle bolt is stripped and I can't put wheel back on. Where can I find a replacement axle bolt?
you need a new axle kit, and a cog removal tool. They used to be a Huret dearailleur if I remember right. I know a varsity never had Shimano. I think you may be better off buying a new rear wheel (it is usually less money than having to rebuild the axle) and let the bike shop do the change over, it is well worth it. You wont have to deal with the brakes,check the cones etc. Why did you have the Meridian adult trike on, and you have an old 10 speed Varsity? Kind of confusing.
Sep 18, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
How do I remove the rear sprocket from a 7-speed
You need a bicycle-specific chain wrench to hold the cassette stationary (for when you reinstall it) and a cssette wrenc to loosen and tighten the lockring on the cassette. You can pick up both of these tools at any bicycle shop. Info on how to perform the work once you have the tools can be found at parktool.com/repair/.
Hope this helps,
matt
Sep 23, 2009 | Schwinn Sport Cruiser Women's Cruiser Bike
How do you use the 21 speeds on the Schwinn ladies coaster bike?
there are 7 cogs on the rear wheel hub; three on the crank hub:
7x3=21 gear change possibilities
large gears move the wheel faster and farther around but, with more effort
small gears move the wheel less distance but, with less effort
i.e. 10 teeth divided by 30 teeth= 3:1 per 360 degree rotation of the bicycle wheel
Sep 07, 2009 | Schwinn Cycling
Cycling Logo
336 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
