Question about Nikon Coolpix 5700 Digital Camera
How much compact flash memory can the 5700 support
  • Nikon Master
  • 3,287 Answers
The Nikon CoolPix 5700 can support up to 1 GB CF type memory cards, but only of a certain brand. Nikon maintains a list of approved cards - those brands and capacities that have been tested to work 100%. Other cards may work too - but no further testing of memory cards is being done with this model camera.
I hope this helps! Good luck!
Posted on Sep 09, 2010
  • 8 Answers
SOURCE: nikon 5700
I think it should take more that 4G's. Maybe it was the way you inserted the SD card. These Nikons can be a bit funny about such things. So if you haven't already sorted the problem I'd suiggest you turn off the camera. Remove the batteries then remove the 'other' SD card. Then reinsert you bigger capacity SD card then the batteries. Then turn on the camera. It's just like re-booting a windows computer. Hopefully it will come up 'roses'. Cheers
Posted on Aug 10, 2008
KCracin
  • 40 Answers
SOURCE: compact flash card
It can if it is compatible, meaining I use the Canon and I have to use the type II cards, it accesses fine.. I wouldn't go to the type IV as I have heard they hang when acquiring pictures.
Posted on Jan 29, 2009
SOURCE: flashcard not working in nikon 5700
Your card is way to big for your camera to recognise. I had a similar problem. The way to fix it is to trick your camera into thinking that the card is only 512 MB. To do this you need to partician your memory card. First go to this website and download this quick free program. (IT WONT HURT YOUR COMPUTER) http://www.box.net/shared/griqir68so as soon as it is download unzip it and double click on Windows Enabler. Put your card in your computer - Then go to start, control panel, administrative tools, computer managment, disk managment, and find the memory card. Down by your clock there will be a new icon with three blue and white windows. Click that and the word ON should appear. Then right click on the drive and click delete particion. Click yes and wait a second for the partician to be deleted. As soon as it deleted right click the drive again and click new partician. Follow the on screen instructions. When you get to the screen for you to pick the partician size the last part is grayed out. Just click the last feild and it will turn on. Type in 512 and then hit next. when you get to the screen that asked to quick format, check the option. Once it is finished your card should work with out any problem.
Posted on Mar 21, 2009
  • 571 Answers
SOURCE: Will by Nikon Coolpix 5700
Your camera uses CF type I or II cards. Since it was first introduced in 2002 I believe it has no support for 4GB cards. But since it's a 5MB camera, you can get some 500 frames on one 2GB card. Just need to pack some more of those for a photo-safari.
Posted on Aug 07, 2010
SOURCE: i inserted an 8GB compact
Did you get a solution to this problem as I have also encountered the same problem?
Posted on Nov 15, 2010
How do i switch from internal to external memory on a coolpix 5700?
If you remove the memory card the internal memory should kick in.
Feb 09, 2013 | Nikon Coolpix 5700 Digital Camera
I own a Nikon Coolpix 5700 and recntly I face a problem with the memory card, The memory card is Nikon Compact Flash 32MB and the camera shoes that I can have Basic 51 photoes, Noraml 26 Fine 13 and Hi...
Nikon Coolpix 5700 Digital Camera memory card failure:
This camera has capabilities which far exceed the data storage of a 32 MB memory card. Put what you can onto the Nikon Compact Flash card and purchase another, larger, 2 GB card for your other storage. This should easily meet both the needs of the camera and your own. The original card must have had data deterioration or a mistake was made in transferring the pictures.
Go to Google and download their Picasa App; it is great for anyone transferring their photography from one storage type to another and you can use it for publishing material to the Web or to your family group e-mail.
Please comment on the success of this solution!
Sciencewoman
Apr 15, 2011 | Nikon Coolpix 5700 Digital Camera
Will by Nikon Coolpix 5700 support a 4 GB compact flash card ??? thanks
Aug 07, 2010 | Nikon Coolpix 5700 Digital Camera
I put in a Compact Flash Card and format with camera and I get a message that it tells me out of memory
I HAD THE SAME PROBLEM. FOUND OUT THAT THE CAMERA WILL NOT WORK WITH A 4GB COMPACTFLASH CARD. APPARENTLY IT CANNOT RECOGNIZE THAT MUCH MEMORY, SO IT SAYS IT HAS NONE. I PUT A 1GB CARD IN IT AND IT READS IT FINE. THESE CAMERAS WERE INTENDED FOR USE WITH A 1GB OR LOWER CARD. (HARD TO FIND IN STORES, BUT LOT'S ONLINE.) THE INSTRUCTION MANUAL SPECS 512MB OR 1GB CARDS.
Jun 24, 2010 | Nikon Coolpix 5700 Digital Camera
My images will not download to computer from Nikon coolpix 5700
If you are using the camera and a USB cord to download, try using a separate card reader instead. 40d3bea.jpg
Feb 10, 2010 | Nikon Coolpix 5700 Digital Camera
Can't change nikon 5700 to Hi resolution
Is the compact flash card full, or close to it? If you don't have another CF card, see if there is a bad pic you can delete. Or maybe 2. Hint: anything out of focus. ;)
Mar 22, 2009 | Nikon Coolpix 5700 Digital Camera
Compact flash card
Jan 29, 2009 | Nikon Coolpix 5700 Digital Camera
Nikon 5700
Thanks! I'll give that a shot.
Jul 14, 2008 | Nikon Coolpix 4600 Digital Camera
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
Sep 08, 2005 | Toshiba e800 Pocket PC
Nikon Coolpix 5700 Digital Camera Logo
737 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
