Question about Nakajima AE-740 Typewriter
How do you clear everything on the typewriter, and set to "default" settings?
    Genius:
  • 1,218 Answers
Switch the machine OFF. While holding down the Margin Release key switch the machine back ON.
The machine should start printing a pre-programmed "self-test."
Switch the machine back OFF...give it 5 seconds then back ON again and you are back to Factory settings.
Posted on Sep 29, 2010
It typewriter how do I reset it. Ibm wheel writer
Turn off.
, remove a battery, wait 30 sec. turn on, everything will set at default settings, replace battery.
DickyO
Oct 14, 2014 | IBM Wheel Writer 1000 Typewriter By...
When I turn the typewriter on, I get a message/code on the screen: 114 08
I have no listing for error 114.08. You can try removing the batteries, turn off for 30 sec. and restart.
NOTE YOU WILL CLEAR THE MEMORY AND RESET TO DEFAULT SETTINGS!!
DickyO
Nov 29, 2010 | IBM Wheelwriter 30 Typewriter
How to clear all codes.
Remove the batteries, turn off for about 30 sec., turn on, all settings will go to factory defaults. THIS WILL ALSO CLEAR THE MEMORY!!!
DickyO
Sep 23, 2010 | IBM Wheelwriter 6 Typewriter
Code 114 08 IBM Wheelwriter 60
This code dosen't show in the operators manual. You can try this,
Remove the batteries, turn it off for 30 sec., restart this will reset everything to default settings. THIS WILL ALSO CLEAR THE MEMORY!!!
DickyO
Jul 07, 2010 | IBM Wheelwriter 30 Typewriter
How to clear a tab setting. Have tried Code Tab set (Clear) and this does not work.
Refer to the op. manual if you still have it... if not you can download one FREE at www.nadist.com .
As a last resort you can try a complete clear...this will reset machine back to factory defaults and clear memory tho.... so if you want to try it... Switch the machine OFF. Then while holding down the MARGIN RELEASE key switch the power back ON.
The unit will begin printing a pre-programmed test page, let it run for half a line and then switch the machine back OFF. Wait 5~10 seconds then switch the unit back On and the machine will be back to Factory defaults.
Jun 30, 2010 | Nakajima AE-740 Typewriter
Tabs are pre-set & won't clear permanently
You are probable in a format mode of some kind. Remove the batteries, turn off for 30 sec., this will set all to default settings.
THE MEMORY WILL BE CLEARED!!!
DickyO
May 14, 2010 | IBM Wheelwriter 30 Typewriter
HOw do I reset all codes in the typewriter? It
Try this turn it off remove the batteries, wait 30 sec. turn on all settings will go to default.
DickyO
Mar 31, 2010 | IBM Wheelwriter 30 Typewriter
You are probably in a format mode. You can remove the batteries, turn off the T/W, wait 30 sec., turn on. Everything will go back to defalt settings.
THE MEMORY WILL BE CLEARED !!!
Tou can get a manual at lexmark.com.
DickyO
Mar 23, 2010 | IBM Wheelwriter 30 Typewriter
Wheelwriter gives 3 beeps when turned on. Meaning?
Try this. Remove the batteries, turn off for 30 sec. turn back on.
This will set everything to default settings. IT WILL ALSO CLEAR THE MEMORY!!!
DickyO
Mar 19, 2010 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter types wrong letters
Try holding the code key and pressing the "L". If that dosen't do it remove the batteries turn it off wait a minite and restart this will put everything at default setting and clear the memory. If you still have the problem Press code "L" hold down the "L" type 001 to set the keyboard to U.S. If this works you need a keyboard for a permanent repair. For a keyboard contact Geo. Beyers Co.
@ 800-392-8085.
DickyO
Dec 14, 2009 | IBM Wheelwriter 30 Typewriter
Nakajima AE-740 Typewriter Logo
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Ron Dufek
Ron Dufek
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
