Machine is slowly agitating no spin - Washing Machines
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Sep 09, 2010
I own a Whirpool Washer machine model LSC6244AW0. I noticed that when the machine is on, the washer agitator spins while the Agitator Auger does not spin. It usually sits in place and sometimes, when
jason,it sounds like your agitator dogs are worn out.you can try just the dogs,part#80040 for about 3 bucks or do the cam kit part#285811 for about20.appliance parts pros.com has a video to help you find the right part for you.hope this helps.
Nov 20, 2014 | Washing Machines
Slow agitation, no spinning
Sounds like that is the issue. If the motor housing is broken then it wont keep tension on drive shaft which means it will operate very poorly, if at all
Nov 27, 2013 | Fisher and Paykel Washing Machines
Wwont agitate
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
May 05, 2013 | Washing Machines
Washer will not agitate or spin
belt could be broken. If not try unplugging for two minutes, then plug back in and open and close lid seven times slowly to reset computer than runs machine.
Aug 15, 2009 | GE Profile WPRE6100G Top Load Washer
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
May 20, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
