Question about Kitchen Ranges
How can you tell if a fuse is blown in my microwave oven? the fuse is solid white and has a gray line going around the fuse
  • 375 Answers
You need to check it with a basic Ohmmeter/VOM/DMM. Unplug. Remove fuse. Check continuity. If there is continuity across the fuse - the fuse is good. You also can use a voltmeter when the fuse is in place and the microwave is plugged in. Just check the voltage across the fuse, if there is any - the fuse is dead.
Good luck
Vlad
First Choice Appliance
Posted on Sep 09, 2010
How do I access the fuses
You may have a bad fuse. It should be located behind the control panel. The fuse will look like the old auto glass fuses about 1/4 diameter and 1 1/4 inch long but made out of a ceramic material you can't see through. Color could be white--brown or a gray color. Amp size will be stamped on the end usually 15 or 20 amps. Should be a few screws around control panel to get it loose.
May 11, 2015 | Whirlpool MH1150XM Convection/Microwave...
Replace a fuse on GE Profile model jvm1871SH02
Unplug microwave or shut off house breaker. Remove grill or cover that goes across the top of door and control panel.Remove screw that holds control panel on and lift up on control panel. It will tilt downward and has 2 tabs at the bottom that go into slots. It can be lifted out of those slots.The fuse should be seen at the top area in the microwave behind where the control panel was mounted. Fuse is usually small 1/4 round type fuse like old type car fuses that were glass but the micro fuse will be either a white of gray ceramic fuse not glass. Some are 15 amp some are 20 amp. Usually stamped on end of fuse.
Mar 01, 2015 | GE Microwave Ovens
Goodmans st101ss microwave no power
please follow this steps and fix it. God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.1_24_2013_5_05_57_pm.gif1_24_2013_5_07_19_pm.gif
Jan 24, 2013 | Tappan TMT157E1 Microwave Oven
I am from Macedonia and I would like to ask you a question about Daewoo Microwave Oven I have. During the exploitation, the white color under the plate, started to exfoliate in a circle, around the...
no its not a health hazard,but if you don't like the looks,they do make a cavity paint especially for microwave ovens,in either a small brush or spray applicator form
Sep 22, 2010 | Daewoo Microwave Ovens
Is there a power fuse on a MCD1611?
Yess there is a ceramic 20 amp 250 volt fuse inside the cabinet. Safety first!!! Unplug the microwave from the wall outlet.
If you remove the four T20 Torx screws that hold the case on(back of cabinet around the edges) and carefully slide the case back and up you can access the fuse. It will be on the circuit board near where the power cord enters. If you have a ohmeter you can check the fuse. The ceramic fuses are not clear so you cant tell a blown fuse by looking.
Feb 16, 2010 | Magic Chef MCD1611 Microwave Oven
No power to microwave?
blown fuse take outer casing off and replace the blown fuse.
You can use a piece of tin foil around the fuse until you are able to replace the fuse.
Sep 07, 2009 | Maytag Appliances Over-the-Range Microwave...
Microwave stopped working when i pushed the start button
Yes. The white inside the glass that you are describing is a blown fuse. To find out what size fuse it is look around the base or top of the fuse. You will see engraved something like "125V 5A. You can pick these up at Home Depot or Lowes in the electrical isle. You can also type www.google.com and enter the word "fuse" and then the size it is. (125V 5A) If you have found this information at all helpfull, please rate my solution. Thanks D. Lange
Apr 23, 2009 | LG Microwave Ovens
BRAVETTI CONVECTION OVEN MODEL K5345H
open by unscrewing screws on back and along left side bottom. this lets you swing up the cabinet showing the electrics. the red power line going to the timer is held in place by a metal wire holder that is riveted to the base. wire has a white sleeve between its insulation and the metal wire holder. slide wire and sleeve out to the side of the holder. slide sleeve to side along wire, revealing fuse. need a solder iron and an electronic parts store to get replacement fuse and solder it in. reassemble.
the fuse is a resistor that blows when unit is getting hot. use lower resistance fuse or just hardwire the power line straight through, no fuse, but watch for overheating (not likely) and maybe use breaker outlet
Oct 15, 2008 | Microwave Ovens
MICROWAVE WILL NOT HEAT
In my case I found an additional fuse, a high tension fuse (5KV 0.8A) in a white on-line isolation slave next to the transformer.
The fuse was blown.
I guess replacing it should solve the problem.
Oct 07, 2008 | Microwave Ovens
Panasonic NN-S789WC - No power on Display, Fuse OK, bulb Lights
The fuse will be a white or gray ceramic fuse, and you really can't tell if it's blown without actually measuring it. If a new fuse blows when you hit START, you probably have a shorted high voltage capacitor. If you have replaced the fuse and still have no display, then it sounds like there's a problem on the control board. The control board has a built-in surge protector which can short (and smoke) and when it does, it will cut the power to the control board, but not blow the fuse. We repair these nationwide for only $39.95 postpaid. If you or a friend want to check it out or send the control unit in for serivce, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 02, 2007 | Panasonic NN-S789 Microwave Oven
Kitchen Ranges Logo
409 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
