Question about Kenmore Washing Machines
Slow flow filling the washer in the 90 plus series (model 110.28942890) top load...both hot and cold water.
    President:
  • 1,430 Answers
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Sep 09, 2010
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 series Clothes washer
there are filters in the fill hose which could be blocked but usually the fault is low water pressure
Aug 31, 2008 | Kenmore 24032\24036 Top Load Washer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
71 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
