Question about Aloha Housewares (93645) Ceiling Fan
Midili White Ceiling Fan - 44 Inch Model: 71608 Hello, I am having issues installing this fan. Please e-mail me the installation instructions because I have lost them. Including pictures.
SOURCE: breeze ceiling fan not working
We have a 52" Aloha Breeze fan that stopped working this evening - fan and light. The remote control was burning up - after reading the other posts I hate to see what else is burning! Sounds like it would be safer to buy a new, reputable fan than spend more money on replacement parts.
Posted on Jul 16, 2008
  • 17 Answers
SOURCE: Aloha Breeze Ceiling fan M# 29081, Fan Switch Problem
call 1-800-295-4448
you need a switch from them the internal mechanism is different. its free of charge
Posted on Dec 22, 2008
SOURCE: Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
Posted on May 09, 2009
  • 6 Answers
SOURCE: Broken ceiling fan switch
NOT ALL SWITCHES ARE THE SAME!!!! Some are single layer and some are not!!. I think you can tell by the body color of the switch. Red and Black, Grey and Black, ETC. I figured this out after buying 3 of the wrong switches. Each one hooks up a little different. If it is an aloha brand fan like sold at WalMart it is a common issue. Just call there 800 number and they will send you a new one. You have to know the exact model number of have the bar code. Usually there is a bar code on top of the motor. Just take it down from the ceiling and look. I called them on Thursday and got a free switch and capacitor on Monday!! My fan is going great again. If you have the old switch check it or just call the fan's customer service!!
Just call 1-800-295-4448. Even the call is free.
Posted on Aug 18, 2009
SOURCE: installaion manual for ceiling fan
there was no manual for my Aloha Breeze 42" ceiling fan with light fixture model number is 49001
Posted on Aug 21, 2009
Wobbling ceiling fan without the blades
IT IS NOT MEANT TO BE USED WITHOUT THE BLADES.
Jun 21, 2015 | Hampton Bay Ceiling Fan. Midili 44 in....
Purchased Hampton Bay Ceiling Fan, Midili White 44", Model #71606 with remote from Home Depot. I have 2 switches wired to the lattter with 1 for the fan and the other for the light. Can I install...
Yes, you could, but you want have any way to control the fan speed. Unless, you install a rheostat that is rated for electric motors. A light dimming rheostat is not heavy duty enough, to handle the fan motor without over heating.
Hope this helps you and thanks for choosing FixYa.
Aug 25, 2011 | Hampton Bay Heating & Cooling
I have a Hampton Bay, Glendale 52 inch ceiling fan/light. I've installed ceiling fans in the past and am used to having 4 wires coming out of the unit - black, blue, white and green. There are black,...
green on the fan is for grounding the device, some have only a braided bare cooper line. grounding is a safety essential and all modern UL tested electrical devices will have some means of grounding to the homes grounding circuit (the bare copper line). check the installation instructions for the proper grounding method. Then you might consider having a qualified electrician install your fans.
Jun 11, 2011 | Heating & Cooling
Installed a Casa Vieja Habitat Ceiling Fan today, the light works but the ceiling fan does not. Please help solve this problem! Thanks!
Check main line electrical wiring connection where it is connected and the switch electrical connection of the ceiling fun.
May 29, 2011 | Casa Vieja Habitat 44" Brushed Nickel...
Reciever won't fit installing Hampton Bay Midili 44 in fan
I had the same problem. Instruction manual is awful. Doesn't mention anything about how to fit the huge yellow receiver either into (a) the mounting bracket or in (the canopy.
After numerous meltdowns, I finally figured it out. Instead of running the live wires through the center of the mounting bracket, run them on the side. The mount bracket to ceiling. If you try to run them through center, you will probably run out of room, and the Receiver will not fit. Once mounted, drop the pin into the mount and turn it until it locks into position.
Next, slide the Receiver in the tight space at top the pin, and just below top of mounting bracket. It will *barely* fit. Then connect all your wires with the wire nuts. Wrap in electrical tape just to be extra careful.
I could *not* get my wires to push up into the ceiling box because the Receiver was blocking the entrance. So I tucked them on the sides, and then lifted the canopy up and finished the installation. All the wires were hidden inside the canopy.
Hope that helps. And hope you haven't lost your mind yet.
God forbid they explain how to instal the receiver, or include a battery.
Hampton Bay = Idiots.
Apr 27, 2010 | Dryers
Light does not come on in the ceiling fan
"from the ceiling fan we have black, blue, and white. On the mounting bracket is green. We installed black and blue from the fan motor to the black in the ceiling."
If your fan is working and the light isn't and they are tied to the same wire (black wire), then you might have a bad pull chain switch or bulb.
Feb 18, 2010 | Hampton Bay 56 In. Florentine IV, Brushed...
I need to install a Hampton Bay ceiling fan Model AC552 but I have no instruction manual. Can I be emailed one.
look into the internet for download of that manual model with the full name of product for instruction manual. try that.
Oct 03, 2009 | Hampton Bay 52 In. White Redington...
I need an instruction manual to put my fan up. I
www.neonlightceilingfanstyles.co.cc/hampton-bay-ceiling-fan-instruction-manuals/ - 18 hours ago
Feb 24, 2009 | Hampton Bay 44 In. White Carousel II with...
Aloha Housewares (93645) Ceiling Fan Logo
101 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
