I need to know the part number for the toner replacement bottle for the Ricoh Aficio 2045 PCL 6
  • 1,110 Answers
Ricoh Aficio 2045 copier/printers take the Ricoh Type 3110D Toner Cartridge. Go with OEM toner on these machines. The generic version tends to make them run dirty.
Posted on Sep 09, 2010
No loading toner my ricoh aficio 3025
you need to replce the PCU - unit order code is
  • B205-0153
  • that depends on the counter number.
  • or the cap from the other toner is still inside the the toner holder.
  • check the old toner bottle does have a cap on it.
  • how ever for i need the print counter to see if the PCU is for replacement.
  • write the print counter, and see do the old toner bottle have ca p on it or is just a open hole.
  • please write some additional info.
  • Best Reagrds
Oct 16, 2016 | Ricoh Aficio 3025 All-In-One Laser Printer
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
Add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Mar 05, 2010 | Ricoh Aficio 2035 Copier
How to replace waste toner bottle for Ricoh Aficio w3600
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Jan 21, 2010 | Ricoh CL3000E Laser Printer
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Feb 20, 2009 | Ricoh Aficio CL2000N Laser Printer
183 people viewed this question
k24674
