Question about Pioneer SD-532HD5 53" Rear Projection Television
There is a rainbow dostortion going through the bottom of the picture, what could the problem be?
  • Pioneer Master
  • 8,457 Answers
The tv have a problems known as a convergence problems,it dead.The tv convergence board require changing 2 convergence ICS and some or all it resistors to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Posted on Sep 09, 2010
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
I was watching my Dynex 32 LCD when picture went out and I had rainbow verical lines going from top to bottom?
did you ever find out why your T.V was doing that? the reason I ask is because mine is doing the same thing rainbow colors
Oct 15, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Why does my Epson Stylus NX300 print a rainbow color band at the bottom of vertical 4x6 pictures
DOES THIS COLOR SHOW UP ON YOUR PRINT PREVIEW?
IF NOT, THAN GO INTO PRINT CARTRIDGES ON YOUR COMPUTER AND CLEAN THEM UP!
THAN DO A TEST ON A SEPERATE PIECE OF PAPER THE SAME PICTURE TO MAKE SURE IT HAS STOPPED WITH THE RAINBOW PROBLEM YOU'RE HAVING.
YOU MAY ALSO HAVE PICTURE SETTINGS WRONG ON YOUR COMPUTER, YOU CAN CHECK THESE UNDER PRINT PREFERENCES.
IF NON OF THE ABOVE WORK, THAN TAKE YOUR PRINT CARTRIDGES OUT AND CLEAN THE CONTACTS WITH SOME RUBBING ALCOHOL AND A Q-TIP.
Aug 25, 2011 | Epson Stylus NX300 All-In-One InkJet...
How to maintain up keep on my rainbow vacuum
Be sure and never store on water basin, keep separator and seal on bottom of rainbow clean. Keep your beater bar clean. You should be good for many many years.
Jul 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Philips HD/TV rainbows the picture at the bottom of set.
Hi, the convergence circuit is getting ready to fail, fix it NOW and you may get away with just resoldering the STK`s, soon they will overheat and short then it`s going to be 250-300 to fix it depending on your area rates, gl, video-tek
May 29, 2009 | Philips 60P8341 60" Rear Projection...
Curved in at top and bottom and rainbow colors on bottom
REPLACE ALL STK?????? CONVERGENCE AMP IC'S & CHECK RESISTORS FOR THAT CIRCIUT
Apr 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
LCD image is greyscale and distorted image vertically
If the LCD and pictures are both bad, the CCD is most likely going south. It is an expensive repair via SONY but I may start doing these far cheaper myself if I get a few customers. pishta68 at hotmail.com
Jan 25, 2009 | Konica Minolta DiMAGE 7Hi Digital Camera
Is my bulb going bad!!!!
Without seeing your Tv it is hard to say what is really going on.
The cloudy picture sounds like one of your "bulbs" needs to have it's fluid changed, not "bulb" replacement.
Rain bowing normally means convergence adjustment or circuit repair is needed.
May 25, 2008 | RCA P52926 52" Rear Projection Television
Rainbow
Rainbow effect has more to do with color wheel style and speed.
Jan 31, 2008 | LG RU-44SZ51D 44" Rear Projection...
Rainbow picture
The tube needs to be degausse you had maybe placed speakers beside the tv causing it to magnetize have a tech look at it to remedy the problem.good luck.
Apr 08, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Pioneer SD-532HD5 53" Rear Projection Television Logo
32 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
