Question about Sharp AR-275 Copier
My ar275 copier has a problem with the developer unit. the developer leaks out when the machine is working. what is the remedy
  • 61 Answers
The corona in the drum unit might be dirty which causes an arc that pulls the developer out, Take drum unit out and there are 2 black tabs with a screw in them, Remove the two screws and remove the corona and clean. Be very carefull not to scratch or touch the drum.
Posted on Sep 10, 2010
Sharp AR275 call for service,the reset is not being helpful.
Must replaced developer and run initialization through service program.
Oct 17, 2014 | Sharp Digital Copier Toner AR235 AR275...
I have sharp AR-5316e and it has CH error non function are working.
CH
ON
None Content Side door open
Detail The side door is open.
Cause Side door sensor abnormality
MCU PWB abnormality
Check
and
remedy
Check that all the side doors are closed.
Replace the MCU PWB.
CH
Blink
None Content Developing cartridge not installed
Detail The developing cartridge is not installed.
Communication with the CRUM cannot be
made in initial check of the CRUM.
Cause Developing unit disconnection
MCU PWB abnormality
CRUM chip abnormality
Check
and
remedy
Check installation of the developing unit.
Replace the MCU
Jul 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
U2-40 error code on AR5012n
U2-40 Content CRUM chip communication error.
Detail
An error occurs during communication
between the MCU and the CRUM chip.
Cause
CRUM chip abnormality.
Developing unit disconnection.
MCU PWB abnormality.
Check and remedy
Replace the chip.
Use SIM 16 to cancel the trouble.
Sep 07, 2010 | Sharp AR-160 Copier
Error U2-40 Call for Service
Clear the trouble with SIM 16.
Details Error in MCU-CRUM chip communication
Cause CRUM chip failure
Developing unit contact trouble
MCU PWB failure
Check
and
remedy
Replace the CRUM chip.
Remarks CRUM communication error
Jul 06, 2010 | Sharp AR-M237 Digital Copier
Developer leaking in imaging unit
yep!
just cleaning all the contract plates and groundings of the process unit (the drum unit and the developing unit).
Jun 02, 2010 | Panasonic DP-8016P Copier
Developer leakage while copying
after replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Feb 06, 2009 | Toshiba e-Studio 161 Copier Copier
Average useful life of Sharp AL-1661CS
With that machine the toner cartridge also contains developer. Without getting too in depth, it sounds like maybe your toner cartridge is leaking a bit of developer which takes with it a bit of toner. Developer is made up of tiny metal particles which are supposed to stay inside the developer unit. As the seals wear in the developer unit (which is part of the cartridge) it allows a little to leak out causing the problems you are seeing.
When you take the toner cart. out, at the rear side (part that goes the furthest into the machine) you'll see a white foam seal. If you notice some excess toner (and probably developer) sticking straight out from that, it could be that the seal has a jagged edge which is dragging developer off of the magnetic roller and depositing it on the drum making the line you speak of on the left hand side.
Also check to make sure the copier is sitting level, if it's not then the concentration of toner at one end of the developer unit is too great and some can be allowed to spill out.
So in short, it's probably not the drum that's at fault, it's more likely the toner cartridge.
Is it worth replacing? There's no easy way to answer that. If the machine is used in a fairly high volume workplace, it's probably worth replacing. If you could get by with a smaller cheaper machine (brother, HP, lexmark etc.) that does printing, scanning, faxing and copying you may be better off.
Oct 16, 2008 | Sharp AL 1631 Copier
Sharp SF-2014 developer
Hello Gus,
IF the Toner/developer is spilling out towards the rear of the machine then the developer unit is going bad. A common problem with this model was the rear bushings in the developer unit would wear out and start to leak. If you take the developer unit out of the machine, put down some newspaper, and tip the developer unit (OVER THE PAPER) about 15-20 degrees towards the back and see if the Developer/toner leaks out any. If it does then you found the problem.
If it doesn't then you might just have an over toning problem. To check to see if you have an over toning problem, please the developer unit ON THE PAPER, get a philips screw driver, and put it in the rear White gear. You will see a series of gears but there is only 1 that is the located on the END of the Roller with the toner/developer on it. TURN IT CLOCKWISE about 1 turn and see if you see toner spilling out.
If you do, then your machine needs a Developer change.
Hope this helps.
Let me know if you have more questions.
If you need parts for this machine, I have a couple contacts that I can give you and you can see if they have the parts in stock.
Good Luck.
Mac
Jun 26, 2008 | Office Equipment & Supplies
My copier 105 canon malfunctioning
the density senson isn't work, it's inside of developer unit
Oct 13, 2007 | Canon imageRUNNER 105 Copier
Sharp AR-275 Copier Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
