Question about Samsung Computers & Internet
I have a Samsung LN32A550P3FXZA LCD flat screen TV. It worked fine one day last week, the enxt day it quit. The backlight is not on. When the TV is powered up, the backlight comes on for about a second, then turns off. I am assuming, from the info that I have read, that it is probably a power supply board, but I hate to order parts that I cannot return, if that is not the problem. Thank you!
hughv
  • 196 Answers
SOURCE: can't turn on PC, Presario SR2163WM
You sound like you know what you're doing, so I expect you've made all the motherboard connections(Same as the original PS). Does the switch work when you test it? If so, it sounds like the PS is DOA. I've had bad luck with cheap power supplies.
Posted on Sep 18, 2007
SOURCE: HP Pavilion a705w power supply
mtn texas , If you PSU cooling fan is not working it could be just the fan. However based on the other facts you have a failing power supply.. Its not dead completely yet but it will be. If you want to contact me direct my email is theflyer_98@hotmail.com... I am a certified Tech and run my own computer repiar business.
Posted on Dec 12, 2007
fwadley
  • 482 Answers
SOURCE: Power supply stopped working
most of the time you need to replace the mother board as well as the power box, it shorts the mother board out.
Posted on Mar 15, 2008
SOURCE: dell power edge 4600 wiht 4 power supply redundant problem
thanks for your no answer !!!
Solucion: apagar servidor, cambiar la posicion de la fuente de alimentacion que marca el error ( el visor LCD indica la posicion de la fuente de alimentacion con error ) y ver si continua el problema.
Sino continua, ok
Si continua y sigue marcando la misma posicion, dos opciones, o es la tarjeta de administracion de energia ( esperemos que no ) o es un fallo del LOG de Hardware, con lo cual, bajar la herramienta DSET de Dell y borrar el LOG ( tercera opcion ) y voila, el equipo como nuevo.
No me molesto en traducirlo porque nadie se ha molestado en ayudarme, lo pongo por si le sirve a alguien.
Un saludo y menos expertos y mas trabajo !
Atte
Posted on Nov 04, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
JVC LT-42E910 LED flat screen TV, backlight comes on, menu box is displayed but after about 5 seconds backlight goes out. Picture and sound still working but no backlight. How can I troubleshoot?
jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
Jan 11, 2016 | JVC Televison & Video
Samsung LCD TV no backlight
Test the power supply board to see if all the voltages are present and within 10% tolerance. Use a voltmeter to verify.
Sep 13, 2015 | Samsung Televison & Video
Over the last couple of days my tv has no picture intermittingly
If the TV is older than 3-5 years or do, it is probably an LCD model with a fluorescent backlight. These backlights have issues with the inverter boards and/or the tubes failing over time. This is why newer flat-panels have gone to LED backlighting. Without the backlight, the picture is actually on the screen, but you aren't able to view it because there is no light to illuminate it. These CAN be repaired, but the cost of new TVs makes it almost most cost-effective to upgrade to an LED TV.
Sep 06, 2014 | Samsung Televison & Video
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a samsung 1080 full hd 38" flat screen tv,
I think the backlight is failing, you will need to have it replaced. It is also possible that the backlight inverter (power supply) may be faulty but that usually shows up a fault. I think it unlikely that the screen itself has failed unless it has been subjected to pressure damage.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Samsung LE40B650T2 40 in. Full HD Crystal...
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung TV screen problems
Your new Tv needs to go back to the dealer. This is not Fixable by yourself...
Nov 12, 2007 | Televison & Video
Computers & Internet Logo
256 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
