Question about Maytag Neptune FAV6800AW Top Load Washer
We have a Maytag MAV7057AWW top loading washer/oversize capacity plus/quiet plus II. It washes and rinses just fine but will not spin adequately - I can wring water out of clothing by hand when the spin cycle is done.
duby1990
  • 370 Answers
SOURCE: My MayTag performa oversized capacity washer wont spin
Usually this is caused by the pump being cloged or broken. Remove the pump and clean the pump out. Make sure it spins freely by hand.
Posted on Nov 21, 2008
  • 183 Answers
SOURCE: Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Posted on Jul 30, 2007
dh1200s
  • 335 Answers
SOURCE: maytag neptune fav6800aww wont spin on rinse cycle
With this post I’m attempting to enhance the troubleshooting process regarding dc/UC errors in Spin Cycle associated with the FAV6800A machine. The troubleshooting steps are more to help DIY owners but it could be good info. for other owners to pass along to their appliance repair service if you go forward with a repair. I’m a DIY’er who refused to junk my machine as long as parts cost did not trigger a replacement decision and I have some basic mechanical skills. What I have learned about these fail codes, dc/UC in Spin Cycle is…. this is a chronic failure condition associated with the FAV6800A series machine (no brainer per numerous posts in this forum) and I feel that most of the time these codes are associated with a clutch malfunction.
The troubleshooting guide packed in the console of your machine makes reference to this issue in the Will Not Spin section of the guide and states to replace the clutch. I re-lubed my clutch with WD-40 and I have been working with 30+ loads of varying size with no Spin Cycle errors since early December 08. I and two other DIY forum members found this issue to be a maintenance issue with the clutch, no out of pocket cost for me and I’m sure under $5 for the other two forum members, I had a can of WD-40 in the house. See the links I have attached within this post. There is a description of the clutch removal I did in those posts. I hope this works for others; I’m sure many of these machines head to the curb for bulk trash pickup. Maybe you can extend the service life of your $1K machine if this proves to be a clutch re-lube fix for this issue. Shame on Maytag for not placing a quality sealed bearing in the clutch…. my opinion.
1. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 2...
2. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it will begin to rotate CCW. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction and the Spin Cycle will fail with dc/UC errors. If this is not the situation move on to step 3. I need to post step 3 and the rest of this post in a comment.
Posted on Jan 30, 2009
  • 79 Answers
SOURCE: MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Posted on Feb 08, 2009
SOURCE: maytag washing machine #mav6260aw
I found the crazy sound where comes from, it was an aluminum ring in the drain pump.
First of all, I took out the belt under the bottom, checked moter to run itself, it was fine, so, I suspected some waste in somewhere, it was lucky I disassembled the drain pump first, no waste in the drain pump, but I saw a ring that was cut under the pump (seems should be connected), when I try to spin the pump wheel by hand it is broken because of the ring.
I ordered the entire drain pump on the website, the cost $74 + delivery fee, I recognized Maytag re-designed the drain pump due to the ring ( new pump does not have the ring anymore). Now the washer works fine like new.
Posted on Mar 11, 2009
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Nov 20, 2008 | Washing Machines
Clanking, sparking sound coming from washer
Need to know a little more info. Need to know if this noise starts when you first turn it on (during the fill up cycle), once the actual washer starts (wash cycle) or when it goes into spin cycle.
Jun 11, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Neptune FAV6800AW Top Load Washer Logo
253 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
