Question about Acer Computers & Internet
When i press power button then no display on lcd/white screen
    Sergeant:
  • 286 Answers
1) When you power on ur pc?? do you get any display in beginning or when windows starts ti gones black.
2)If no display from the beginning??? try pressing caps or num lock key and see whether led on keyboards are blinks or not?
3)Do you get any beep sound when you try to power on??
Posted on Sep 10, 2010
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Oct 08, 2009 | Nokia N70 Cellular Phone
The display on my inspiron 6000 in jumpy at the bottom 1/3 of the screen. no evidence of any damage to case or screen. Just started with a black line and now jumps around and has white lines in the bottom....
Generally the problem is caused due bad LCD inverter cable. Kindly run the LCD diagnostics
How to Run diagnostics
1. Shut down the computer
2. Disconnect the AC adapter and Battery
3. Press the power button for 10 sec.
4. reconnect both AC adapter and battery
5. Press FN key+ power button
6. Follow the screen prompts.
If the LCD problem is shown in diagnostics your screen would have to be replaced.
Thanks for using Fixya
proton
Jul 27, 2009 | Computers & Internet
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
I have a Dell Inspiron 9300
if there is white line in the middle of the screen then first of all turn off the laptop and disconnect the ac adaptor and take out the battery and press and hold down the power button without the power cord and the battery for one minute and then turn on the computer with power cord and the battery and then check it out and still after that if u get it then check it out with the external monitor and if u get a good display in the external monitor then replace the lcd,but make sure that the screen is not broken from inside which u cannot touch and feel it.and if u get a good display in the external monitor then definately replace the lcd screen....good luck
thanks
Dec 27, 2008 | Compaq Presario M2000 Notebook
Doesn't start
hi, if ur screen turns white, it could be any problem starting from ur LCD to motherboard or as u said a virus. to assist u in a right way i need to know what exactly is happening between that short duration between pressing the button and white screen. most importantly is anything else comming up on the screen before the white screen.
cheers
Oct 12, 2008 | HP OmniBook 500 Notebook
Philips 150B4 White Screen with the word Aging...
I have a philips 19 lcd. the damn thing just display a white screen with the word aging in red in the certer. it goes off after a while, turn black a while then comes back again, with the white screen. keeps doing it over and over.
anybody have any idea?
i tried caps, but all the caps look good.
to be noted i didnt change all.
Apr 20, 2008 | Computers & Internet
Philips 170S4 white screen not display.
its in the power suppy section,most of the lcd monitor has this problem,try to check the capacitor electrolytic or replace all th 16v capacitor
Apr 03, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
