Samsung DLP model hln5065w My problem sounds similar to many I've read about here. TV makes a high pitched whine, unlike the noise emitted from a defective color wheel. The lamp will not light. The TV will attempt to cycle on and off several times before giving up and flashing all three lights on the front of the set. I replaced the color wheel, lamp, and ballast. No change. I insured the rear detector switch was properly depressed, and even jumped it once to be sure. No change. Also, if I plug and unplug about 10 times, the tv will come on. The picture is dim with verticle lines running across the front (IIIII IIIII IIIII IIII). Help!!!
  • 1 more comment
  • lenwill61 Sep 09, 2010
    This may be beyond my real of expertise. In the past, I've easilly replaced simple components with good results. This level of testing seem somewhat more complex. Is there perhaps a "gremlin" in these components that is likely the source of the problem. The television was play properly and then suddenly began the problem I've described
    I was told to check voltages across the power supply to narrow down the problematic components. I was hoping the described problem could be more simply traced to a specific part. Any direction would be appreciated.
  • lenwill61 Sep 10, 2010
    Thank you very much Ladywinn! I checked the power supply board, and nothing seemed amiss. I'm beginning to wonder whether it's worth the trouble to continue buying parts for this television when the prices of new ones are in range of the money I've been spending. I think it's now me versus the machine :) Where do you think I should look next?
  • 5,138 Answers
On left hand side board up front power supply board look for defective Capacitors they will be vented,swollen or Puffed up on Top 680uf 25v 220uf 10v 3300uf 10v.
Google to this Website and Type in your Model # for PartsList and Prices. Encompass Parts Distribution 1-800-638-3328
They have Free Service Manual you can print it out online for HLN5065W.pfd
Let me know if you need any more help.
Posted on Sep 10, 2010
  • 11,800 Answers
The lines are caused by the image processor that can't read the memory buffer because it's undervolted - something is wrong in the power source.
The whine is caused by the power source that is overstressed by a short. Take a look at it, especially at the capacitors. Disconnect everything attached to it and test the output voltages, they will give you a clear indication on where is the faulty part located.
Posted on Sep 09, 2010
  • Azrael SRL Sep 09, 2010
    From what you describe a component just failed. The only thing you will be able to do is to look very carefully for damaged parts: bulging capacitors, burned resistors, or bad deformed transistors and replace them all.
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Piaggio mp3 125cc motorcycle, won't start and emits high-pitched "whining" noise, last garage-serviced October 2012
chec alternator for health--sounds like bearings are bad--du u gut a repair book for that model--git one online or checout library sec 629--its a basic component so othr manual can help u
Feb 25, 2013 | Piaggio Motorcycles
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Samsung DLP TV repair or replace that is the question!
Color wheel sounds like it needs replacement. The set will often shut down when the color wheel gets bad and wont power up.
Jul 10, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a Samsung DLPTV, picture is fine. There is a "whining" noise associated with the TV the whole time its on. Stops as TV shuts down, It's about 4 years old and have not replaced lamp. Could this be...
Google your model number; I suspect it is a bad color wheel--lots of these sets have a fan like noise or even a grinding sound sometimes called a high pitched whine.
The part can be customer replaceable and YOUTube has actual video instructions for its replacement.
Let me know if you have questions as I am here to help.
SD TECH---Steve
Jun 08, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung DLP is making a loud humming noise
Most likely if you are hearing a fan like noise from this DLP it is not the fan.
These sets use a replaceable color wheel that before it fails makes either a high pitched whine or a fan like sound.
Part is usually customer replaceable and there are free written instructions and video instructions on YouTube for most models.
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Nov 23, 2009 | Samsung HLN5065W 50" Rear Projection...
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
Samsung DLP Model HLP 4663 WX Constant Whining
What you're hearing is the most likely the color wheel if you remove the lamp you can see part of it ...a multicolored plastic disk.It rotates on a high speed motor and make an awful whining noise when it fails.
Rustym62
Apr 30, 2009 | Samsung HLN5065W 50" Rear Projection...
High pitched whine when the motor starts
Had the same problem. It quit within about 5 seconds after turning the TV off. Replaced the color wheel and the whine is gone. The picture also looks brighter, which may be due to dusting the projection lens with lens-cleaning compressed air (from a can). The color wheel was about $100 from Samsung parts and it took less than 3 hours to replace. See http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ for good info, and be sure to read the cautions.
Aug 07, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
