Question about Acer Extensa 7620-4021 Notebook
Jag har ett problem med min brännare på min acer data acer extensa 7620g först slutade brännaren dvd/cd rewritable drive model ds-8a1p att fungera med vissa dvd bränn skivor sedan funkade bara vissa sorter sedan funkade inga skivor alls det står i nero att bränningen misslyckades efter några sekunder varje gång. är det något fel på brännaren?
  • 565 Answers
SOURCE: Looking for the Acer Extensa
manual can be found here - http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=01d95435f44ffa9941b456e44c950ef7&q=Acer+4620Z
Posted on Dec 26, 2008
  • 52 Answers
SOURCE: acer extensa 4630z windows complete restore
I wrote to Acer myself about this and this is their reply.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
  • 27 Answers
SOURCE: I have an ACER 3610 laptop with a HL-DT-ST RW/DVD
That particular drive that you have is a cd writer. It can only read DVD's not write them.
Posted on Dec 02, 2009
  • 20 Answers
SOURCE: New Acer Extensa 5635Z laptop, won't brun DVD's
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena5
Posted on Jan 03, 2010
SOURCE: My laptop is Acer Extensa 7620G...I want to change
Screws ... under plastic with little covers ...typical covers is always hidden ... don't forget if something block your plastic,and you can not open in 90 % cases is screws ... I need see this model Acer Extensa..
Posted on Aug 23, 2010
Reparar mi paint drive kinston
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps you
Klicka p? Start Kontrollpanelen administrive datorverktyg Management h?rddisk h?gerklicka p? enheten v?lj Egenskaper Klicka p? verktyg du b?r se p? Kontrollera nu Klicka p? Start tv? boxar automatiskt ?tg?rda filer och s?ka efter och f?rs?k att reparera skadade sektorer plats sedan ett kryss i b?da rutorna och v?lj sedan kontrollera nu b?rjar eller s? kan du kryssa i en ruta att sedan ?terv?nda efter avslutade den f?rsta reparationen sedan ?terv?nda och markera den andra rutan ska du inte g?ra n?got medan chkdsk p?g?r n?gon ing?ng kan skada den h?r enheten
Jag tyckte att du f?r b?st resultat genom att kryssa i en ruta sedan ?terv?nder efter att det har slutat sedan markera den andra rutan
hoppas att detta hj?lper dig
Sep 18, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Nao roda o dvd..
Klicka p? Start p? panelen Verktyg administrive, Datorhantering Enhetshanteraren scrolla ner CD-DVD ROM-enheter du kan se ett gult fr?getecken? h?gerklick kommer du att ha m?jligheter att uppdatera drivrutin ?terst?ll tidigare drivrutin, eller v?lj egenskaper Allm?nna fels?ka, v?lj f?raren klicka f?r att installera om drivrutinerna p? Uppdatera drivrutin eller avinstallera sedan installera om detta inte l?ser problemet kan det vara ett problem i registret om du inte kan se din h?rddisk i Utforskaren
St?ng alla ?ppna program
Klicka p? Start, K?r och skriv regedit och tryck p? Enter
Klicka p? plustecknet (+) bredvid f?ljande mappar
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Kontroll
Klass
{4D36E965-E325-11CE-BFC1-08002BE10318}
Denna mapp ?r DVD / CD-ROM-enhet Klass Beskrivning i registret. Leta efter n?got av f?ljande namn i den h?gra kolumnen.
?vre Filter
L?gre Filter
?vre Filters.bak
L?gre Filters.bak
Om n?gon av ovanst?ende knappar som visas i steg 4 visas, h?gerklicka p? dem och v?lj Ta bort
Efter bort nycklarna, st?ng Registereditorn
Starta om datorn
?ppna Den h?r datorn och kontrollera om din cd-eller dvd-enheter har ?terv?nt. Du kanske ocks? vill ?ppna Enhetshanteraren och kontrollera att den gula utropstecken och felkod p? CD eller DVD-enheten ?r borta. eller
du kanske m?ste fysiskt koppla ur leder till denna CD / DVD sedan in dem igen detta b?r aktivera guiden Ny maskinvara eller
kanske du m?ste avinstallera starta om datorn installera din DVD / CD sedan installera om drivrutinen f?r denna enhet
Om datorn levererades med ett moderkort disk drivrutinerna kan vara p? det
Klicka p? Start Kontrollpanelen administrive verktyg Datorhantering Enhetshanteraren scrolla ner cd DVDROM enheter om du ser ett gult fr?getecken eller utropstecken? ! eller ett r?tt X h?gerklicka m?ste du uppdatera drivrutinen eller
v?lj Egenskaper allm?n fels?kning, v?lj f?raren klicka f?r att installera om drivrutinerna p? Uppdatera drivrutin
Sep 09, 2011 | LG GSA-4160B DVD±RW Burner
Hej jag har prolim med lexmark cover open
Det kan vara patronerna i bärselen. öppna skrivarens lucka och ta bort bläckpatronerna. Kontrollera cylinderampullen område för några hinder i bärselen vägen. Om inga, stäng locket. Koppla ur och tag bort skrivaren till strömkällan att återställa sig själv. När skrivaren slås , sätt tillbaka bläckpatronerna och kontrollera att de sitter i rätt och säkrade. Stäng locket. Försök skriva ut igen.
May 04, 2011 | Lexmark X3480 All-In-One Printer
Hur gör jag för att skydda min router genom att ha ett lösenord????
TR?DL?S TRYGGHET FR?GOR
Steg 1: Anslut router - Computer (Wired)
Steg 2: ?ppna Router Setup genom att skriva http://192.168.2.1 i adressf?ltet i Internet Explorer
Steg 3: P? v?nster under tr?dl?sa Klicka p? Wi - Fi Protected Setup
Steg 4: L?mna l?senordsf?ltet tomt och klicka p? skicka
Steg 5: Inaktivera det och klicka p? Verkst?ll f?r?ndringar
Steg 6: P? v?nster under tr?dl?sa klicka p? S?kerhet
Steg 7: Aktivera 64 bitars WEP
Steg 8: Skriv ett 10-siffrigt nummer p? nyckeln 1 (2 i varje kartong)
Steg 9: Klicka p? Utf?r ?ndringar
Steg 10: till v?nster under tr?dl?s klicka Kanal och SSID
Steg 11: ?ndra den tr?dl?sa kanalen till 6
Steg 12: ?ndra SSID till ett annat namn (utan mellanslag)
Steg 13: Klicka p? Verkst?ll ?ndringar
Steg 14: Nu Scan och ansluta till detta n?tverk (tr?dl?st)
L?t mig veta om det fungerar
Oct 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hej!Jag har en CASIO EX-Z150. När jag sätter på kameran säger den att kortet är låst. Jag vet inte vad jag ska göra. Det går inte att göra nånting med...
Ibland finns det en liten str?mbrytare p? sidan av SD-kortet som g?r det m?jligt att skriva till kortet av och p?. Om det misslyckas ?r det f?rst med ett annat minneskort.
Aug 19, 2017 | Casio EXILIM Zoom EX-Z150 Digital Camera
Nearly all webcams have a control center but not
Please click here to download the latest version or firmware and drivers for the camera in your laptop.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 09, 2010 | Microsoft LifeCam VX-1000 Webcam
Pentax istd autofocus actuator stopped working repare advice ? where to get parts ?
Hej!
Jag kör Windows vista opertivsystem 32 / 64 med en moderkort P573-CM ASUS, Grafik cort V621 ASUS med Vga driver V721 ASUS .
Vid start av data visas felkod c800002 och samtidigt har jag fel med tillfälliga avbrytning i pågående seral / film inspelningar både med ljud och bilder, därför undrar jag om dessa problemet är i sammband med felkod av c800002 också ?
*Tack för tips och rådgivning.
Mvh
Jul 22, 2009 | Pentax *ist DS Digital Camera
Free download of singer overlocker manual
Jag har en industri overlock singer 81k73 Jag kan inte trä den
Har du några förslag
Mar 25, 2009 | Yamata FY14U4AD
INSTRUCTIONS FOR ADJUSTING POD510 TIME WATCH
Pod Watches Customer Service
C.I Services
P.O.Box 2016
Bolton West
BL5 3YH
Telephone number (Service Centre) International +441942 845 614/ 00441942 845 614
UK 01942 845 614
give them a ring and ask for a copy of the manual.
Aug 26, 2008 | Watches
Abit BL7-RAID
Please formulate question in English, or submit to general questions
Thanks
Apr 17, 2008 | Abit BL7-RAID Motherboard
Acer Extensa 7620-4021 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
