The spacer on my msntv2 keyboard has stopped moving. Can it be repaired?
    President:
  • 2,777 Answers
It is much easier to just replace the unit.
Posted on Sep 09, 2010
Loose swinging arm
Lay the bike on its side. Superglue the bush to the swing arm. Lay the bike over the other way and repeat. Do not glue the bush to the shaft.
Nov 27, 2014 | 2009 Harley Davidson FXDC Dyna Super Glide...
My msntv2 won't power up. A green screen comes up and says refer to error code #131.
I got the same problem a few days ago error#131 on my msntv2 unit. Tech support at msn said to start with the power on ---then push and hold (alt) and push power and release both at the same time and the power should shut off.--- Then push and release Power and Immediately push and hold down (alt.)---Then a Orange light should come on---Then release the (alt) key--- then enter 5532 5532. If that does'nt work then try starting with the power off---Then push the OK button 3 times then push 5532 5532. Mine didnt work so I dont know what happens after that. Good luck
Apr 30, 2012 | RCA MSN TV 2 Digital Media Streamer...
My line spacer 1 & 2 green lights are flashing. Will not let me type or do anything. I changed the batteries, don't know what else to do.
I don't think you have a WW3500 as they don't have lights, if it is a WW1000 the keyboard is bad you can try my repair under WW1000 or contact Geo. Beyers Co. @ 800-392-8085 for a keyboard rebuild.
Tell them O'Reilly sent you.
DickyO
Apr 14, 2011 | Lexmark Wheelwriter 3500 Typewriter
Sound stopped coming out from teh tv speakers. i have to run it through my stereo system
Hello, I am John at J. D. Electronics. You have a D4 model. This is caused by a defective spacer under the A / V board. This is not recommended for owner repair, since it involves removal of other PCBs, Sheilds and "spacers" and connectors. On the A / V board ( the one with all the jacks ), is an audio IC that normally runs fairly hot. Therefore, the MFG had to use an aluminum heat sink on the top and bottom of the IC. The problem is that there is a "clay like " spacer pressed between the bottom PCB at the audio IC and an aluminum plate, or heat sink, underneath that sets against the metal back of the LCD panel. Here is what happened; The "spacer " turns into a "sticky goop" causing the whole pcb move towards the Heat Sink under the A / V board. This causes the connections at A / V pcb at the audio IC to come in contact with the bottom aluminum heat sink, thus shorting out the audio IC and then no sound or popping noises. This is common on the D4 and D6 models.We charge about $325 for this repair since it is very time consuming. I have repaired dozens of these sets with this problem. I hope this helps! John
Jan 27, 2011 | Sharp Aquos LC37D44U 37 in. LCD HDTV
The sound on the TV completely stopped in the middle of a program. There is no sound at all now, even when the cable TV is disconnected. I tried checking all cords and wires to the speaker and TV.
Hello, I am John at J. D. Electronics. You have a D6 model. This is caused by a defective spacer under the A / V board. This is not recommended for owner repair, since it involves removal of other PCBs, Sheilds and "spacers" and connectors. On the A / V board ( the one with all the jacks ), is an audio IC that normally runs fairly hot. Therefore, the MFG had to use an aluminum heat sink on the top and bottom of the IC. The problem is that there is a "clay like " spacer pressed between the bottom PCB at the audio IC and an aluminum plate, or heat sink, underneath that sets against the metal back of the LCD panel. Here is what happened; The "spacer " turns into a "sticky goop" causing the whole pcb move towards the Heat Sink under the A / V board. This causes the connections at A / V pcb at the audio IC to come in contact with the bottom aluminum heat sink, thus shorting out the audio IC and then no sound or popping noises. This is common on the D4 and D6 models.We charge about $325 for this repair since it is very time consuming. I have repaired dozens of these sets with this problem. I hope this helps! John
Nov 22, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to disassemble a MSNTV2 unit
msntv2 boots up and then turns off repeatedly with no video or the video will be towards the bottom of the tv screen why?
Feb 15, 2010 | RCA MSN TV 2 Digital Media Streamer...
I bought 15 used MSNTV2 units from a government liquidation auction with the hopes of reselling them for a profit. I failed to realize that these are password protected machines and there isnt much you can...
Ruismall is halfway there. You must hold down the MSN power button on the keyboard while typing the magic number 32768. Wait a while until the TV screen goes blank, then power up again. I had to power up twice, but I did finally get the "Welcome to MSN" screen.
Nov 18, 2009 | RCA MSN TV 2 Digital Media Streamer...
Hedge trimmer blade not moving
I have a Troy-Bilt gas powered hedge trimmer. My blades would not move. After tearing it apart, I found that there were some spacers under the 5 or 6 screws along the blades. These spacers are steel and designed so that you don't overtighten the screws. However, around those steel spacers, there is a teflon type material that makes the oval shape of the slot. That teflon had fallen apart and lodged so that the blades would not move. I removed the teflon and put the spacers back in and it now works fine. There is a little play between the spacer and the edge of the slot and it will probably eventually wear out but at least I got a few more cuttings off of it.
Jul 04, 2009 | Black & Decker Black Decker 16" Hedge...
FRONT WHEEL SPACERS 97 TRIUMPH DAYTONA 1 OR 2
i think the speedo drive has a little molded ridge on it which should slide into a slot on the fork leg, thus stopping the drive from spinning round the spindle. drop the front spindle out and align the drive correctly and then slide back the spindle and bolt it all up and you should be all good to go.
Mar 27, 2009 | 1999 Triumph Daytona 955i
IBM Weelwriter 5
You probably need a new keyboard. Check and make sure the 2 keyboard connectors are secure in the main board. Open the top cover and look down by the keyboard and you will see the connectors. Keyboard costs about $ 75.00 to repair. Plus labor for a repairman to replace it.
Sep 26, 2007 | IBM Wheelwriter 30 Typewriter
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
