Question about LG LRSC26980 Refrigerator
Lg refrigerator broken water line at base of freezer door
  • 159 Answers
SOURCE: Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
Posted on Jul 13, 2007
  • 6 Answers
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Posted on Aug 07, 2008
SOURCE: G.E SxS REFRIGERATOR
Ice maker works- door water dispenser does not- light comes on when dispenser is pushed.
Posted on Nov 27, 2008
  • 14 Answers
SOURCE: kenmore coldspot freezer door water line
I had the same problem and I would like to replace the whole line inside the door, it was best to get a double sided connector from an appliance parts store. The part cost me about 7 bucks. I then had to So far so good and when cut a small piece out of the front guard where the connector goes. you take off the front guard, measure where the tube broke. The connector comes off when you push one side down.Cut the edge of tube to have a straight edge, but just a little at a time. Just a clean straight edge, it does not have to be perfect!! I used a small pair of needle nose pliers to pull the bit of hose down from the freezer side and then i used my connectors. It just takes a little time and effort. Let me know what happens!!
Posted on Apr 04, 2009
  • 14 Answers
SOURCE: Replacing water line in freezer side door
Yes as I stated on other posts, go to an appliance shop and get a threaded connector. Mine cost about $7 and i had to do some minor adjustment cutting to the plastic guard at the bottom of fridge/freezer...so the new piece would not put too much pressure on the line. The white coupling connector on the line u will see has a red and blue washer conected on eitrher side of water line. To disconnect line ..just push in on top of washer and pull line. Cut the torn lines so u at least have a line that is clean and mostly straight, but dont cut TOO MUCH!! just the bare edge, about 1/8 " inch. Use some needle nose pliers ,real small ones.. to pull the line from bottom of door and apply connector. Put lines back on and do faceplate and check for leaks. Good luck!!
Water leaks from bottom of freezer door
You need to remove the door from the refrigerator, then remove from the door the plastic frame carefuly, its snaping, and attach the new (1/4") line to the end of existing line then pull up the existing line softhly until the new one appears, check before all this if the line is broken at then of door or in the middle and if leak is below the refrigerator check from the solenoid to the door.
Jun 13, 2014 | Hotpoint HSS25GFP Side by Side...
Lg french door refrigerator water leak underneath, when you use water in the door you hear a hissing sound.
Sounds like a hole in water line. Shouldnt be too much to fix. Hardst part is finding the hole
Aug 23, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
I have lsc27926st. The water tube to the ice tray froze and I used a hair dryer to unfreeze it. After the tube was clear the water will not refill the tray. I have turned the on/off switch a couple of...
from the ice freezing tube may have caused valve to burn up on unit... these are normally plastic water valves on back side of unit lower right side... very common problem... i am a lg oem authorized servicer parts usually come from lg electronics in alabama unless you have a local supplier that you can go to...        the ice makers themselves have been problems on these models as well... 1 year warranty is all they give and usually 1 year 2 days they go out...   let me know if i can help anymore    ACHEATINGUNLIMITED@YAHOO.COM         TEXAS BASED APPLIANCE /HEATING AND AIR COMPANY
Dec 31, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
LG Refrigerator
  • the drain line in the freezer may be clogged forcing water to drip into the freezer. clean out the freezer and pour some hot water in the back of the freezer to unclog the drain.
  • another cause of this would be if the door is not sealing properly then the inside of the refrigerator will build up condensation.
Jul 05, 2008 | Refrigerators
Water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Nov 21, 2007 | LG LRSPC2031 Side by Side Refrigerator
LG LRSC26980 Refrigerator Logo
93 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
