Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
We have a KitchenAid KDI-16 we wish to replace. It is under a counter and is surrounded by white enamel panels. Are these a part of the unit or were they added. It seems that the space occupied by the KDI-16 is not large enough to hold a new under the counter 24in. Do the sides come with the unit or are they an add on?
  • burkhead Sep 10, 2010
    Thanks. We suspected as much. I suppose that there is no way of fitting a new Kenmore 24in built in washer in the existing space. The old Kitchen Aid still works and we just might keep it!
    President:
  • 1,891 Answers
The kdi is a mid line kitchen aid dw . the model that you have may have side panels as they were a opt at that time . is is a standard 24 in dw . and if replacing with dw in todays world any 24 in wi fit . you will need 24 wide 34 and1/4 + height and 24 is standard for depth .. most dw will fit this standard size mm ps any sides will be a add on .. and the old ones will not fit .. mm
Posted on Sep 10, 2010
  • KitchenAid Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description it sounds like you`re describing an old portable dishwasher which was built into the cabinets at one time, hence the side panels you`re referring to.
Unless you`re purchasing a new portable unit, it will not come with panels on the side.
Once you remove that unit from the cabinets it will much better to observe the panels on the side as being part of the unit.
Hope this helps move you forward to your new machine, let me know if you need anything further.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Sep 09, 2010
  • Mark MacDonald
    Mark MacDonald Sep 11, 2010
    Hello again,
    Sorry for my delayed reply. I usually receive an email from FixYa notifying of any reply to a post, but I either missed it or never was sent...likely me not seeing it.
    As to your question about whether a new unit would fit, I suspect it would...but it's better to remove the old unit and measure the exact dimension you have to work with and then find out what you would require to install a new one in that place.
    They aren't ALL the same and I'm sure you could find a match to your needs. On the other hand my inclination would be to keep the old unit if it is still functioning well, cleaning the dishes, even if it is likely many decibels louder than most modern machines, ha ha.
    What ever you decide I would like to prepare you for one thing, It will only be superior to your old Kitchen Aid in one category...energy consumption. In all other areas, especially durability, it is an "epic fail" in my opinion...no matter what brand.
    Consider this to be one of my many grievances with modern appliances. In a world where we are capable of producing machines to be superior in every way compared to the old machines, we continue to make "trow away appliances" for the cause of energy efficiency...seems like a paradox to me, but oh well. I just fix 'em, I don't make them.
    Hope this answers your question. let me know if I can assist you further.
    Good luck.
    Macmarkus :)
Which boards should I replace (Y, X, Main etc) to fix red pixel speckles appearing in a white or light image?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 03, 2015 | Samsung PN60F5300AF 60" 1080p Plasma TV -...
Kitchenaid dishwasher imperial 21
Take the kick panel off under the door and see if the technical spec sheet is there. That lists all the diagnostics that you can run
Nov 20, 2013 | Dishwashers
I need a top rack part #9741982 for my old Kitchenaid Dishwasher!!! Can anyone help me? thanks so much!
If you contact an appliance dealer that sells kitchenaid I'm sure they'll be able to get it for you.
Jan 09, 2012 | KitchenAid Dishwashers
Can I replace the white exterior door panel with stainless steel?
Yes you can replace the panels. There are 3 panels. The problem is only 2 of the 3 panels are availble. The large panel can be found here:
http://www.appliancepartspros.com/part_details.aspx?part_id=4508020 or here:
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS25SHBS1/0593/0130000/P9080030/00001?blt=06&prst=&shdMod=
The panel below that panel is no longer available so you would end up with a large stainless panel and a white panel below that.
I checked several sources for the panels. All 4 of the sources that I checked state the panel (item 5 of above link) is not available.
Also the bottom toe panel is black (Item 8 above link) on the stainless model. You could sand and paint your existing one (enamel) black.
Thanks for choosing FixYa,
Kelly
Feb 25, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
Why is my machine making a horrible knocking noise?
Top load or front load?
Top load it could be the support arms for the tub. The top panel should lift back on hinges after you free the front clips. Make sure you do not have to loosen any screws under the lid as some models are different. You can use a small wood wedge or a putty knife with duck tape on the blade so you do not scratch the enamel paint and gently pry up the front of the top panel. Once you lift the panel back you can inspect the arms which support the tub and easily replace the defective support or rubber shock absorber.
Front load it could be a lose counter weight. Pull the unit out from the wall and unplug it. Remove the back panel and check the counter weight to see if it is attached to the top of the drum
Jan 06, 2011 | Hotpoint Washing Machines
Mouse inside housing
Ouch, I wish you the best of luck with this.....
You will definatly have to slide the unit out from under the counter, dont forget the two or three screws at the top of the washer to the cabinets or counter, and if it has side panels over the insulation, you will have to access the first set of screws from underneath the dishwasher. Sometimes removing the front door helps. Careful not to lose screws, and expect that you'll have to re adjust the unit to fit back under the counter by leveling it. Do your best not to mess up the current setting of the levelers unless there is a floor height difference that will prevent you from pulling it out. (i.e. tile kitchen, and no tile under dishwasher)
When you slide it back, make sure not to pinch hoses, (feed or drain) level it as best as possible, and replace all screws!
Jul 30, 2009 | Kenmore Dishwashers
38 year old kitchenaid KDI-16 imperial dishwasher
yep you can just get springs from lowes or home dept or your local hardware store; they're often in with the hardware (i.e., screws) and not plumbing. remember that the springs need to stretch out a bit, too; so you may end up buying springs that look shorter than they should, but they eventually habituate.
Jul 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Paddle is rubbing the bottom of the mixing bowl
It is going to low down. the adjustment should at the back of the unit.
Mar 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My kitchenaid dishwasher heating element looks as if a coating is coming off of it in a small area. I would like to replace the element...how is easy is it to replace.
I just replaced mine. I ordered the part from Kitchenaid and just got it today. I turned the power off at the breaker, turned the water valve off under the sink. Two screws hold the machine in place under the counter top. I slid the machine out about 8-10 inches and disconnected the water supply tubing on the bottom left side of the machine and then was able to pull the whole dishwasher out from under the counter top. on the bottom in the back are two white plastic hex nuts with a wire connection going to each. I pulled the wire connections off each and loosened the white plastic wire nuts. Then I went into the washing tub where the heating elements is. I shook the two contact ends loose and pulled the element out. I put everything back in the reverse of this. You will then need to reset your panel by pressing the sani wash and the heat dry buttons back and forth a couple of times. All the lights will then go on and the machine will reset itself. Give it a go. Best to ya!
Oct 11, 2008 | Dishwashers
Microwave enamel wearing away
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Enamel should work, but appliance paint is better.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 20, 2008 | GE JVM1650 1000 Watts Microwave Oven
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
55 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
