Question about GE JKP15 Electric Single Oven
Put my self cleaning oven on self cleaning and a code of F2 came up and won't stop beeping. What do I do?
  • 101 Answers
Bad board,and or sensor
Posted on Sep 10, 2010
SOURCE: F2 message when self cleaning
I have the exact problem, had a service man look at it while still under warranty. He said it was fixed and left. Tried it again, same problem. Called him back 2 times after that, he quit responding to my calls. By tyhen warranty expired and GE refused to do anything.
Posted on Dec 16, 2007
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
vitg55
  • 70 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
MY REPAIRMAN
  • 61 Answers
SOURCE: F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Posted on Jan 25, 2009
localwonder
  • 6784 Answers
SOURCE: f2 code
Hi, this will occur if the oven control senses the oven temperature above 915F-930F
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Posted on Jul 19, 2009
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
I was using the self clean mode and after about an hour and a half, it starting beeping and the code F2 came up. I cleared it, but the door is locked and I can't open it. I even turned off the power for...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 16, 2010 | GE Ovens
Self clean results in f9 and beeping
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Dacor single oven flashes an F2 error code and won't stop beeping!!!
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Oven
Aug 07, 2008 | Ovens
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
F2 error
what is solution
Dec 08, 2007 | Ovens
Nov 07, 2007 | GE JKP45 Electric Double Oven
GE JKP15 Electric Single Oven Logo
218 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
