Question about Sharp AL-1457 Black and White Copier
My copier is printing large black lines on one side of paper
  • 52 Answers
CHECK THE WAST TONER CASE, IF IS NOT FULL,CLEAN THE MIRRORS AND THE LENS IF THE PROBLEM PERSIST CHANGE THE CLEANINING BLADE.
Posted on Sep 10, 2010
4 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
Bubbabear64
  • 2794 Answers
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Posted on Jul 20, 2008
M2Tech1
  • 313 Answers
SOURCE: My Kyocera Copystar CS-2114 Copier is printing a
have a look at the scanner glass especially the thin strip glass this is the glass that is used when passing paper through the document feeder. if you do a copy from the main glass or print to it and no line apears there is probably dirt or tipex or a ink mark on the surfac, the other thing to look at os the drum charge unit as htese can sometimes fail to connesect correctly at the back and not sit tight in the slot this means the drum isnt charged on the edge.. good luck
Posted on Nov 17, 2009
I have a Epson pro large format 9600, I print on canvas, I have use Photo black since I have it, but never getting a saturation ressult. I have been counsil by Epson to use Matt black rather than Phot
"Photo black" is designed specifically for glossy photo paper. Matte black is for non-glossy paper, including plain paper. Matte black will print darker on non-glossy paper than photo black does.
Oct 28, 2014 | Epson Office Equipment & Supplies
Have black lines on left side of paper after printing
Usually this is occurs when the drum needs to be changed.
Jun 05, 2012 | Dell 3100cn Laser Printer
Blue,black thick line and print is not so glossy
I work on the doc 12 every day. first look at fuser web once out look at the metal roller in side the web slot make sure there is no build up..the large gray fuser rolls should be covered with oil coatting so make sure the oil is pumping.
Jun 30, 2009 | Xerox DocuColor 12 Printer
Large black ink tank is not being used by the printer.
The little cartridges are pigment for photo printing. The Large black cart is ink for plain paper (usually text) printing. If you select a photo paper in the print setup menu, you will use very little of the ink.
To check the function of the large cart print out a test sheet from the printer maintenance menu. You may need to run a head cleaning to get all the nozzles to work.
May 11, 2009 | Canon i860 InkJet Photo Printer
I have an okidata 320t that is loading wierd. The alarm light is on when I put a paper in the top feed the alarm light goes out, but the paper doesn't load untill you push the SEL button and then when you...
1st try the easy stuff is the leaver set as paper feed or tractor feed if that is set correctly then you most likley have a gear problem and they need to be replaced.
open up the printer replace all the gears on the right side and the large gear on the left
they cost about 8 euros each and if it does not park correctly just clean out the bits of paper stuck under the paper load leaver the leaver is small black and bobs up and down if it does not bob up and down it means that there is a bit of paper stopping it. (to do this you have to remove the large black roller that feeds the paper)
thanks Hackeridis
Apr 16, 2009 | Okidata 320 Turbo Printer (Remanufactured)
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
Black streak on one side
Stop the print with a little practice, half to 3/4 of the way threw machine by opening door at right time. You want the paper to be jammed/stopped after the drum (has image on paper) but before fuser (print should still rub off)
fuser is blue green 300 thingy
If print is line less where stopped then mark is from fuser, replace
If print has line before fuser then it is drum/cartridge
..probally drum..need more info to know for sure, ie you say mark when faxing I guessing you mean receiving, what happens in copy mode is same as printing I'm assuming too
Nov 08, 2007 | Canon imageRUNNER 1370F All-In-One Laser...
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Sharp AL-1457 Black and White Copier Logo
164 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
