Question about Denon Audio Players & Recorders
Protect display appears. No sound at all. We try to reconnected the speakers but no luck. Please help!
  • 163 Answers
Most likely the receiver has an internal hardware problem like a bad channel. Need to repair it.
Posted on Sep 10, 2010
I have Kenwood kdc- mp343 it displays protect then what happens?
Disconnect all speakers from unit. Turn on. If still in protect then unit is damaged and needs repair. If not then reconnect 1 speaker at a time until it goes into protect. That speaker is either shorted or wiring is shorted.
Oct 30, 2016 | Kenwood Car Audio & Video
Harmon Kardon Receiver "Protect" Mode issue
If your receiver enters protect mode with no speakers connected, it is an indication that you will have to start troubleshooting inside.This will involve visual checking and checking with a multimeter to isolate the problem. A further issue is finding out why your JBL woofer keeps blowing fuses. It could be shorted.
Dec 12, 2013 | Audio Players & Recorders
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Keeps flashing PROTECT when switched on
Check all of your connections very carefully. If all seems well, disconnect one wire at a time, then power on after each wire is disconnected. Alternate between power off (remove a wire) then power on. If the PROTECT comes back on, reconnect the one wire and then power off. Disconnect the next wire, power on, and see if the PROTECT comes back on. If so, reconnect that wire and continue until all of your wires are checked. If at some point after disconnecting a wire and powering back up, the PROTECT does not appear, that wire you just disconnected is the culprit and needs to be replaced. Even a single strand of speaker wire crossing to another opposite polarity (speaker wire) or input can cause a fault making the receiver "PROTECT" itself. Although it may be tedious, it is effective to trouble shoot this way for the first step. If you want disconnect all wires from the receiver and then power on to see if it does it independently of any other connections. I hope this helps and good luck. Please vote 568462d.jpg below if this is helpful.
Oct 30, 2009 | Sony STR-DE345 Receiver
Protect appears on display on kenwood kdc 3034
Disconnect all the speaker wires at the receiver and turn it back on. If itdoesn't go into protect mode, your receiver is ok.
Reconnect the speakers one at a time being sure to turn the receiver off each time you connect a speaker and turn the receiver on until your receiver goes into protection mode again.
When it goes into protect mode again, the last speaker you connected has a problem. Trace the speaker's wire to the speaker looking for cuts or shorts along the way.
If you have a multimeter, switch itto ohms and check the speaker for a dead short, if you show a dead short you have a blownspeaker. Hope this helps.
--Matt
Oct 07, 2009 | Kenwood Car Audio & Video
Sony STR-DE475 - no surround sound
Thanks for all the info. It appears that the Receiver requires service as there is no test tone also. However, please clean the speaker cables and speaker jacks and reconnect. Also, try the steps mentioned in the link below.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C216020&fes=true&mdl=STRDE475
Sep 26, 2009 | Sony STR-DE475 Receiver
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
On display is says "protect" what does that mean?
Try disconnecting the power supply to the back of the mp232 then reconnecting it. This worked for me AFTER doublechecking all of my speaker connections.
Mar 22, 2009 | Kenwood KDC-MP232 CD Player
Vollume trouble
the system protect is usually displayed when a condition of short or shorting is occurring in the speaker wiring or the voice coil of any of your speakers.... thte circuit of you reciever is trying to protect itself and you from a very costly repair,,,so it you have another set of speakers try to use them and see if the condition still exists and if it does the problem is in the output section of the receiver,,,and if the protect no longer exists you have fixed your problem,,,good luck
Apr 07, 2007 | Onkyo TX-8211 Receiver
System keeps sayin protect
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged, or look if the wires arent shorting. If it stil ldoes that, its cause there is a short in it, from the output section. The system does that to prevent from damaging the electronic components inside.
Nov 17, 2006 | JVC MX-K30 CD Shelf System
46 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
