Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser shuts off when light bulb is installed. i'm using the right wattage bulb. but soon as i install the light bulb in the dispenser the water stops and the display panel show the temp. model number is ESF25KGTBBB
  • 101 Answers
Need dispensor board
Posted on Sep 10, 2010
How to change the light bulb
Hi
Not all bulbs will fit your refrigerator. Be sure to replace the bulb with one of the same size, shape and wattage. On some models, the dispenser light requires a heavy duty 10-watt bulb. All other lights require a 40-watt bulb.
1. Unplug or disconnect power from your refrigerator.
2. Remove light shield when applicable.
NOTE: To clean the ligt shield, wash it with warm water and liquid detergent. Be sure to dry the shield thoroughly before installing.
3. Remove the light bulb and replace it with the same size, shape and wattage.
4. Replace light shield when applicable.
Also check this link bellow:-
http://whirlpool.custhelp.com/app/answers/detail/a_id/1403
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My 600 watt 12 volt transformer timer for out door lighting does not keep time properly. HOw do I get and install a new timer?
1) Amazon sells 600Watt power pack:
http://www.amazon.com/Malibu-8100-9600-01-Voltage-Power-Transformer/sim/B002ZRPM4A/2
2) I bought new 300Watt Malibu power pack at Home Depot about 2 months ago.
Near the lighting section.
My new power pack has electronic time clock, so no more 'slow clock.'
I think Home Depot had 600Watt.
Lowes carries different brand.
3) Manuals for power packs at Malibu lights.com
http://www.malibulights.com/customer_service/owners_manuals.aspx
4) Tips for buying and taking care of power pack:
-Match up wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
5) How to install power pack.
Before unplugging old power pack, check which bulbs are not working.
Replace bulbs using phillips screwdriver.
Unplug power pack.
Notice how wires are connected to power pack, write down terminal connections.
Some power packs have three terminals ... extra terminal is for additional photoelectric eye.
Use pliers or screwdriver to disconnect wires.
New power pack has has same terminals.
Plug in power pack.
Read instruction manual before connecting wires.
Save instruction manual because a few years that manual won't be around as products change.
Dec 03, 2010 | Malibu Intermatic Inc. ML121RT Low...
I need to view a manual for this item, Is it online?
Malibulights.com manuals
Guide for setting up lights
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
Tips for power pack:
Nov 22, 2010 | Malibu ML200RT - Low Voltage Power Pack...
I have the ml121rt transformer. the lights work fine but the dial on the timer doesn't spin on its own to keep time so i have to manually turn them on and off. what can be done?
Power pack is getting electricity.
Connections are good where lights tie into wire.
My power pack was doing same thing.
I tried everything from spraying WD40 to trying to taking it apart.
Power pack doesn't come apart.
I turned it upside down thinking water or dirt got into timer.
I took it inside and let it warm up.
It still wouldn't work.
Then I searched Intermatic and Malibulights.com for answer, but they have no troubleshooting or repair.
Conclusion: when power pack doesn't work, it is broken.
I found tips to preserve power packs, but over the years I pretty much followed these steps and power pack still failed.
1) Match wattage of bulbs with wattage of power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
Nov 19, 2010 | Malibu Intermatic Inc. ML121RT Low...
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
The lights stay on all the time and won't shut off. The front ones work fine but not the back lights. Any idea's? thanks,
Unfortunately when the power pack stops working there is no solution.
Your power pack has electricity so that is not the problem.
The bulbs turn on, so the bulbs are ok.
That means the power pack has malfunctioned, and needs to be replaced.
I did find some tips to help folks preserve their power packs:
Nov 12, 2010 | Intermatic Malibu 121W Power Pack...
The timer feature of my Malibu 300 watt power pack just stopped working. The lights can still be turned on/off manually. Anything I can do other than buy a new one?
Nov 12, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Chasnge light for water dispenser
Dispenser
Unplug the refrigerator.
The bulb is located on the dispenser
under the control panel.
Remove the light bulb by turning
it counterclockwise.
Replace the bulb with a bulb of the
same size and wattage.
Plug the refrigerator back in and you are ready to go!
Thanks, Sea Breeze
Apr 25, 2010 | GE Profile Arctica Stainless Steel Top...
I have a problem with my kitchen's recessed lighting. For some reason, the six bulbs will go out during the evening hours, then come back on. There is no pattern, with one, two, three or four of them out...
It sounds as if you may have higher wattage bulbs and/or the wrong type of bulb installed in the can fixtures than the recessed cans are rated for.
When the wattage of the bulbs is higher than the rating of the fixture, and/or the wrong bulbs are being used, the recessed can's thermal overload device will shut off the light, to prevent damage and a possible fire situation.
It is unlikely that you've got a faulty dimmer, since you state that not all of the lights go off at once, thus it can be narrowed down to each can and thus the thermal overload being the culprit.
I would suggest you look inside the recessed can light fixture and determine what the maximum wattage bulb you can use, (60, 75, 90 watts, etc.) and use the next lower wattage bulb instead. I also install only Halogen bulbs in recessed cans, (they have a flat lens vs. a rounded bulb lens area like PAR type bulbs). Halogen bulbs are also the most efficient incandesent bulb that provides the whitest light possible and directs more light (and thus heat) downward away from the recessed can.
I avoid using a standard light bulb or PAR type bulbs in any recessed can fixtures as they tend to heat up quite a bit and cause the thermal protection to trip frequently.
As a Master Electrician that has installed literally thousands of recessed fixtures and dimmers, I can say that my customers prefer the Halogen light over standard bulbs and they last longer too.
I hope you find this Very Helpful and best regards!
Sep 17, 2009 | Lutron Diva Dv-600P Light Control By
My low voltage landscape lights are constantly going on and off once the timer activates them initially. I suspect there is a short somewhere, but is there a good way to locate the short besides pulling up...
Your transformer must have output greater of the total wattage required of the entire system. Example: Putting lights that draw a total of 250 watts with only a 180 watt transformer will result some lights not working, or dimming and flickering, or intermittent power outtages. I learned this from experience. Always go with a transformer that has more wattage available than what is needed. Also, using the incorrect gauge of wire can cause the same issue. Wire creates resistance. Distance the power must travel through the wire creates more resistance at the end of your run than the beginning.
Mar 29, 2009 | Garden
GE (PSS26MSRSS) Side by Side Refrigerator Logo
100 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
