Question about Angeles Bye-Bye Buggy Stroller
Do the shoulder straps in the bye bye buggy come out to be washed?
I removed harness to wash and have refitted shoulder straps but adjustment ******** Viaggio Primo SIP wont thread through and under buckle . can you advise please
To figure out how to do this with the Peg Preggo Viaggio Primo SIP, I think it's best to contact their customer service:
1-800-671-1701. Customer service hours are Monday - Friday 8am - 4:30pm Eastern time.
Feb 10, 2013 | Baby Gear
How to remove a back seat from 02 toyota avensis
Hi, peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat.
Extend the set belts to their maximum length and recline the seat as far as possible.
Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions).
On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the ****** belt at the bottom.
Unhook the looks from the shoulder straps from the metal clasp.
Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to wash.
Thank you.
Jun 06, 2012 | Cars & Trucks
My stroller on the back right hand side feels like
Hi
Visit www.buggypitstop.co.uk/ quick and expert advice plus can fix it for you at a reasonble price.
thanks
Apr 29, 2010 | Angeles Bye-Bye Buggy Stroller
How do i adjust the shoulder straps to a bigger size
http://www.mountainbuggy.com/resources/uploads/documents/Buggy%20Instruction%20Manual.pdf
here you go. We had the same problem :-)
May 23, 2009 | Mountain Buggy Urban Single Stroller
How do I put back together the straps on my car seat
would assume you're talking like a booster seat with the back just no 5pt harness. You just buckle them up like you do. If they have those arm rest looking things, the part where it buckels goes under that one arm rest and the shoulder strap should go resting over his shoulder like yours. Some of them have a loop up top for the shoulder strap to go through. Just make sure that the toddler does NOT put their arm over the shoulder part of the belt. If you get into an accident this could break his/her ribs.
Apr 20, 2009 | Britax Eclipse Si - Paris Convertible Car...
Having trouble with straps in car seat
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps.
Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat.
The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it
doesn't twist, either.
There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side.
Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.)
One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
Dec 30, 2008 | Cosco Juvenile Scenera Convertible Car...
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
I have a 02-442-PRI 11-17-98 Cosco
If you washed the straps, they will need to be replaced. Lock the harness together, to prevent the straps from being twisted. Feed the top part of the harness through the slots that are AT or ABOVE your hangchilds shoulder if the seat is forward facing. IF the seat is for rearfacing, feed the top part of the harness straps through the shoulder slots at or BELOW the child's shoulder. Once each is through, reach down and attach them to the silver plate that hangs from the **** strap adjuster. Once you silde each of the harness straps, then slide the bottom of the through the hole in the cover, then into the base of the seat, folding the top like a triangle makes it easier to get through the tight holes. Repeat on the other side and you are ready to travel! Thanks!
Jun 16, 2008 | Cosco High Back Booster 22-200 /22-207
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Baby Gear Logo
67 people viewed this question
Top Angeles Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you an Angeles Baby Gear Expert? Answer questions, earn points and help others
