Question about Kenwood Audio Players & Recorders
I have two kenwood crs-157 rear speakers and they stopped working. I'm not sure what happened. I dont know if i overloaded them or what.
I have a kenwood kdc bt43u and transferred it, with my amp and rear speakers, to an identical vehicle. It all works fine until i use bluetooth. sound only comes from the front factory fitted speakers
Not quite sure what you are saying here but I am going to take a stab. If I am filling in the gaps but are the rear speakers wireless? If this is the case then they are not paired with the speakers but with your receiver deck. You will need to pair the speakers as well before it will play through them.
Dec 21, 2014 | Kenwood Car Audio & Video
I do not know how to wire nenwood kdc-422 to a 94 buick century?
You should have a wire harness pigtail that comes with your kenwood.
you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model.
Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do.
All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car.
match up each wire as described here:
1994 Buick Century Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 22, 2010 | Kenwood KDC-422 CD Player
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
How to hook up a kenwood car sterio in a 1992 saturn sl2 car.my radio was stolen and a bought a kenwood and we dont have the color codes for wiring them together
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Stereo Illumination Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Feb 06, 2010 | Car Audio & Video
Dont know if you can help but....I just bought an older model pick up(1989 toyota)it had no radio in the dash, I have a Kenwood CD player i want to install but I dont know the color codes of the wires in...
Nice radio installer link HERE
Check out the lower wiring guide.
A Right Front Speaker (+) Green Gray
B Left Front Speaker (+) Pink White
C +12 Volt Ignition Wire Gray Red
D +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
E Right Front Speaker (-) Blue Gray w/ Black Stripe
F Left Front Speaker (-) Purple White w/ Black Stripe
G Ground Wire Black Black
H Power Antenna Wire 1 Blue (join wires 1 & 2
I Power Antenna Wire 2 together to this blue wire)
J Do Not Use
K Right Rear Speaker (+) Red Purple
L Left Rear Speaker (+) Black Green
M Right Rear Speaker (-) White Purple w/ Black Stripe
N Do Not Use
O Do Not Use
P Left Rear Speaker (-) Yellow Green w/ Black Stripe
Dec 14, 2009 | Car Audio & Video
Not sure what wires go from the head unit go into the car
Blue with white stripe is usually a remote, you probably wont need it. Im not sure about the Brown or plain Blue.
Mar 25, 2009 | Kenwood KDC-MP228 CD Player
Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Dec 04, 2007 | Pioneer VSX-D608 Receiver
My Kenwood 800watt amplifier
Sounds like you have overloaded your amp. When you bridge you MUST make sure that you still have the proper speaker load. One 4 ohm speaker on one channel is fine, but when you bridge that same 4 ohm speaker, it gives you a 2 ohm load on each of the two channels that are now bridged. If you made the mistake of wiring two 4 ohm speakers in parallel (plus to plus and minus to minus) then when you bridge you will be driving a one ohm load on each channel. This is very close to a dead short. Stop using your amp at once until you get your speaker load correct. This will damage your amp and it will cause you to have to go to a repair shop to fix it. DO NOT RUN YOUR AMP ANYMORE UNTIL YOU FIX THIS. Good luck.
Jan 22, 2007 | Kenwood KAC-9152D Car Audio Amplifier
No sound from speakers
In most recivers or amps yes if there is a short in one channel all the amps go into shutdown or into the protect mode. Now if you know how an amp works then you should be able with a schematic to find out what amp is causing the over load simply by see in the schematic where the speaker output is on the curcuit and then measure for a DC B+ . Thats the amp you would disconnect to conferm that all the others were ok as an output on an amp curcuit shouldnt have more then .3 to .8 volts dc unless its unbalanced.. Seek a pro to assit you if you dont have the equipment to test the amp and for sure get a service manual or schematic diagram. Good Luck
May 16, 2006 | Kenwood VR-5080 Receiver
Shutting itself down
Its usually not a fault that you will see unless somethings burnt up. This is solid state electronics and you dont see this stuff go bad. But in the meantime try disconnecting the speakers and see if it still goes into shutdown and at the same time have a dc multimeter attached to the speaker outputs. If the unit comes on and you dont see any DC at all or very very little B+ on both speaker terminal sets then you may have a defective speaker. If you do see dc then thats why the protections comming on so you dont blow out your speakers. If you dont have any equipment or dont have any electronics experience I would then take the unit to a repair person for an estimate. Good Luck
May 06, 2006 | Kenwood VR-707 Receiver
98 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
