Question about Canon imageCLASS D780 All-In-One Laser Printer
I have a paper jam. i did everything in the troubleshooting guide. no paper found. however, the place where the copy comes out is where i did find the jam. can.t get it out because i can't take the part out at this part of the copier. do i need a repair man or can you help?
  • sricc17 Sep 09, 2010
    is there a way to get the paper out, before i see if i need a new roller? thank you
    Genius:
  • 1,478 Answers
Among the most common problems with any make of copier are paper jams. A copier will jam for any number of reasons: It’s dirty, the wrong paper type is being used, or the rollers on the copier that feed the paper through its pathway are worn down. While cleaning the copier periodically and using the correct paper type are easy fixes, also, the roller may need replacement, the roller is a difficult task to replace, i will advice you get a repairman to help with that.
Take care.
Posted on Sep 09, 2010
  • Jimoh Adeleke Muyideen Sep 09, 2010
    Open
    the covers and access panels in the copy machine to clear the paper
    path of jammed paper. Gently extract the paper from between rollers so
    the edges and corners of the paper don't get torn. Even if the original
    cause of the jams is resolved, scraps of paper left inside the copier
    from clearing the paper path will introduce new paper jams.
    Open
    the paper cassettes and remove all the paper. Inspect the paper for
    damaged edges and corners. Fan the paper thoroughly, then reload the
    cassette. Check the paper guides to be certain the guides are not set
    too tight or too loose. Misaligned guides will cause paper jams in the
    copier
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Paper jam sign appears after first copy
if jam indicated but no paper is found. clean the roller that feeds paper out of the paper tray.also make sure paper guides are touching paper front rear and left side.
Feb 23, 2014 | Ricoh FT5832 Copier
I REMOVE THE JAMMED COPY. PRINTER STARTS AGAIN AND JAMS UP AGAIN ON THE VERY NEXT COPY. COPY SEEMS TO BE MADE BUT CAN'T GET OUT OF THE EXIT
Jam may not be completely cleared or paper is not suitable for your printer.
You can find your User Guide, an Educational Guide on the paper which is compatible with your printer and updated Drivers here:
http://my.okidata.com/PP-B4350.nsf?opendatabase
In the Troubleshooting section of the User Guide (page 74 of the English version) there is a section on dealing with Paper Jams. Make sure you have cleared all areas and that your paper is compatible.
Trust this is helpful. Please vote.
Dec 25, 2010 | OKI B4350 Laser Printer
If the paper is jam in the printer
Without more specific information on where the jam is occurring in the printer difficult to provide a specific solution.
However, if you are having problems with paper jams you may find it helpful to work through the interactive troubleshooting guide found on this page under the Troubleshooting tab:
http://www.samsung.com/sg/consumer/pc-peripherals-printer/printer-multifunction/mono-laser-printer/ML-2510/XSS/index.idx?pagetype=prd_detail&tab=support
Under the FAQs tab on the same page you will find 3 guides for avoiding paper jams and 1 guide for clearing paper jams.
Trust this is helpful. Please vote. Thank you. :)
Dec 21, 2010 | Samsung ML-2510 Laser Printer
Hello I'm Gera I need a solution to my brother all in one printer DCP-185C. I'm printing and copying yesterday october10, 2010, but the screen displayed paper jam then i get the paper then copying again...
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Nov 11, 2010 | Brother Office Equipment & Supplies
LexMark x3430 printer
Here is a guide of all possible paper jam locations on the X340 printer. http://bit.ly/cS4lpm
If still no paper is found on any of those places then the printer has a faulty sensor. Depending on the paper jam numeric error is the sensor that may be failing.
Feb 12, 2010 | Lexmark X340n All-In-One Laser Printer
I want now what's Common faults in Aficio 2035
THe main problems are toner spill form drom/dev units ..the transfer on the right hand door will have to be emptied every few months. the paper tray paper stops need to be checked as they come out of place and cause paper jams if not set in place..cahrge rollers can be troublesome if not cleaned every coulple of months and may cause dirty image at the sides or lines on copies..dust on laser **** glass can cause faint on sides of copies.. the fuser stripper fingers tat guide the paper need to be checked for toner under the points to stop paper jams in fuser and the lower guide plate entrance to the fuser needs to be cleaned off every now and then to stop crinklin of paper...apart from that good machine
Dec 17, 2009 | Ricoh Aficio 2035 Copier
I am getting a supply Rec Paper Cassette alarm error. How do i fix this and have it work again.
Hi ..
This error comes when the paper is not loaded properly in the cassette ... Follow the below instructions to load the cassette and I am sure you will not get the error again.
  1. Grip the cassette handle, and pull it out towards you until the cassette comes to a stop.
  2. Open a package of paper, and remove the paper stack. small_note.gif black_dot.gif If the paper is curled, uncurl it before placing it in the cassette. Failure to do so will cause paper creases and a paper jam. black_dot.gif 17 lb to 20 lb bond (64 to 80 g/m2 ) paper is acceptable. black_dot.gif The cassette holds up to approximately 500 sheets of 20 lb bond (80 g/m2 ) paper.
  3. Load the paper stack beneath the cassette's length guide (1) and width guide's claw (2).
    load_paper_in_cassette.gif small_note.gif black_dot.gif Make sure that the paper stack does not exceed the length and width guides' claws in the cassette. Failure to do so will cause a paper jam. black_dot.gif Do not load extra paper when there is still paper left in the cassette. black_dot.gif Only load one size of paper into the cassette. Do not load different sizes of paper into the cassette at the same time. black_dot.gif Do not load labels or transparencies into the cassette.
  4. Gently insert the cassette as far as it will go.
small_note.gif black_dot.gif The cassette is for plain paper, colored paper or recycled paper only. Loading other paper in the cassette may cause a paper jam. black_dot.gif If copies are curled, or a paper jam occurs, remove the paper stack from the cassette. Turn it over and then place it in the cassette. black_dot.gif If you load paper while making copies, do not load a different paper size.
Closing the cassette When closing the cassette, make sure to push it in completely as far as it will go. If copying is performed when the cassette is not pushed in completely, it will cause a paper jam.
If copy paper is sticking out of the cassette Sometimes, when you pull out the cassette, paper may stick out, as shown in the illustration below. Make sure that the paper is neatly loaded into the cassette, before you push the cassette back into the main unit.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon imageCLASS D860 All-In-One Laser...
My Canon MP140 has a paper jam. How to open and remove paper?
Click here. This will take you to the Canon support page for your MP140 printer. Click on the 'Support and Service' tab.
Where it says ask a question type in 'paper jam'.
Next click on the required link, which should give you detailed instructions or a link to help you with your paper jam.
If this helps, click YES below.
Jun 30, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
DI3510f
Try to reload the copy paper in the LCT staight and even and also make sure the sides of the paper guides are flush against the paper in the paper tray...
May 19, 2008 | Minolta Di3510f Bizhub Copier
Canon imageCLASS D780 All-In-One Laser Printer Logo
153 people viewed this question
old marine
old marine
