Question about Casio FX-9750GPlus Calculator
I need to be able to display my answers as radians, e.g ?/3. Please help
  • Casio Master
  • 7,993 Answers
To get results in radians you must configure the angle unit to be degree.
  1. In Run screen press [SHIFT][MENU] to access (SETUP).
  2. Use Down arrow to highlight the line Angle :
  3. Press F2 key to select the TAB Radian.
  4. Once you do that all values (input of trigonometric functions and polar graph functions OR output of inverse trigonometric functions) are in radians.
However I believe I sense a misconception in your request. You can press [SHIFT][x10^X] to enter PI, but the calculator will never give you an angle result as a fraction of PI. You will have the numerical approximation of it that corresponds to the number of decimal digits you are keeping.
Posted on Sep 11, 2010
  • k24674 Oct 01, 2010
    Sorry. The sentence
    "To get results in radians you must configure the angle unit to be degree." does not make sense.
    It should read
    "To get results in radians you must configure the angle unit to be radian."
Key for 1987 yamaha yx600 radian
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
need key for Radian YX600
Yamaha YX600 Radian Ignition Key Switch 86 88
Yamaha YX600 Service Manual
OEM parts for Yamaha
http://www.badrad600.com/Radian%20Manuals%20-%20Complete%20-%20Printable/Radian%20Owner's%20Manual%20Clean%20Complete%20Final.pdf
Nov 22, 2013 | 1987 Yamaha YX 600 Radian
The math problem is x2= 85-84 cos25 and it doesn't work on the fx-260
85-84cos(25 deg)=8.87015 and I do not see how you get 3. If angle is in radians the answer is 1.73896. Make sure your calculator is configured to use the right angle unit (radian, degree or gradian).
Jan 19, 2013 | Casio FX-260 Solar Scientific Calculator 1...
Wrong trigonometric answers
The sine of 0.5 radians is about 0.4794, so your calculator seems to be giving you the correct answer in that case.
The sine of 0.5 degrees is about 0.00872, which your calculator may be displaying as something line 8.72 times ten to the negative 3. Look to the far right end of the number: do you see "x10-3" with the "-3" superscripted? In that case, again your calculator is giving you the correct answer.
Sep 10, 2012 | Casio FX-115ES Scientific Calculator
Lost keys, no key code yamaha radian
Hi, Loopsta_009 for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Lost my bolt only key
Aug 01, 2012 | Yamaha YX 600 Radian Motorcycles
My tangent button is giving me wrong answers.
When you are handling trigonometric functions and their inverses, the results depend on the angle unit your calculator is configured for.
When angle is in degrees, tan (1/2)=8.726867791x10^(-3)
When angle is in radians, tan(0.5 radians)=0.5463024898
It seems that your angle unit on calculator is set to degrees, while it should be set to radians.
Jun 14, 2012 | Casio FX-300MS Calculator
I am a casio fx-82MS user. i would like to know how i can convert polar form to rectangular form in my calculator
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
Nov 13, 2010 | Casio FX-115ES Scientific Calculator
Casio fx-300es---how to convert radians to degrees
You use the key combination [SHIFT][ANS] (DRG>).
If the default angle unit is degree
Type in the angle value in radian, say 1.2.
Press [SHIFT][ANS] (DRG>).
The screen displays 1: deg symbol, 2: a raised r for radian, and 3; a raised g (for grad).
1.2 [SHIFT][ANS] (DRG>) [2: raised r] .
The screen displays 1.2 with a raised r to the right of the 2.
Press [=].
The answer is 68.75493542
Dec 02, 2009 | Casio fx-300ES Calculator
Wrobg answer whenever I use radians
To avoid problems,set your angle unit to radians by default. Press [MODE]. If Radian is highlighted (text on black background), it is indeed the default mode. If Degreee is highlighted, scroll dowm to the line and use the left arrow to select Radian and press ENTER. Radian will start blinking.
Any number you feed a function that acts on angles (sin, cos, tan) will be considered in radians. Any result that comes out of the inverse trigonometric functions (arcsin, arccos, arctan) is in radian. The angle coming from a conversion from cartesian coordinates to polar coordinates is in radian.
You have a simple way to convert the value from radians to degrees because 1 rad=180/pi. Store this value in a variable [STO->] D
180/[2nd][PI] [STO->] D
Since the last result is always stored in [Ans] all you have to do is to multiply by D: [Ans][x][ALPHA]D converts results in degrees.
Hope it helps
Sep 14, 2009 | Texas Instruments TI-83 Plus Calculator
Using Tan,sin, cosin
Alot of people seem to be having this problem. Angles can be measured in two units, degrees and radians. Your calculator is currently doing everything in terms of radians. I have an 84 but I'm sure the 83 is similar, go under MODE and look for Degrees and Radians and make sure you choose degrees. if you have to convert 360[degrees] = 2* pi [radians]
(easy to remember, 360deg in a circle, 2pi radians in a circle)
Good luck
Aug 11, 2009 | Texas Instruments TI-83 Plus Calculator
TI-89
Angle mode, Degree/radian setting, Chapter 2, pg 53 (pg70 of 623) Tan instructions pg 510 (appendix A pg 527 of 623) Here's your manual, download this file: http://www.ti-89.org/uploads/ti-89-manual.pdf
Jun 07, 2007 | Texas Instruments TI-89 Calculator
Casio FX-9750GPlus Calculator Logo
156 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
