Question about Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Describe your deep scratches Problem my 2 yr old took a razor blade and made 11 scratches on the screen. tried the vasalin trick didnt help. i dont think their deep enough for that trick.
  • Sony Master
  • 8,457 Answers
Sorry,u can't not fix scratches on LCD screen,there are no chemicals compound that work yet,u have to live with it.
Posted on Sep 09, 2010
How to remove silicone from glass?
Hi, you need windex and new razor blades.Spray with windex where the silicone is and clean it with the blade.Based on how big is the area that you clean you might have to change the blade few times.
Its important to go with the blade only in one direction not back and fort so you dont scratch the glass.
I hope that helps.
Jul 18, 2014 | Building Materials
Scratched computor screen
How deep of a scratch is it on the screen? Just on the plastic/glass protective coating over the monitor?
If it is not in the LCD then you could just remove the plastic/glass and replace it if you want.
If the scratch is deep then your LCD is probably scratched. Sadly the cost of replacing the LCD screen within an LCD monitor is more expensive than buying an entirely new screen. Your best bet is either dealing with the scratch or getting an entirely new monitor. I would recommend visiting www.newegg.com where there are many cheap monitors there.
please rate my solution
Jul 20, 2010 | Acer AL2016W 20" LCD Monitor
PC Moniter with scratch
You can't get the scratch out, since it's embedded there by metal. you can patch it up with clear tape or use glare reduction monitor screen.
Mar 06, 2010 | Computers & Internet
Someone posted asticker on my car window and it wont come off easily any ideas?
razor blade,get an old school razor blade and the flatter you scrape it the better the result,its like shaving glass and it doesnt scratch,and if youre really cool use glass cleaner while you do it and its super smooth.....just wipe it when youre done,I used to scrape stickers off car doors from the nursing service,vary carefully this way and it didnt scratch....just remember keep blade as flat as possible
Oct 26, 2009 | 1997 Honda Civic
What size deep well socket do you use on 1999 chevy blazer?
usually its either 13 mm 14 or 15 mm socket thats all and just make sure you get all of the old gasket off when your taking the old one off or you will have a leak when putting the new 1 on just take a razor blade to it thats al..
Thanks,
Steve
Jan 18, 2009 | 1999 Chevrolet Blazer
Sharp front panel replacement for 42" LCD t.v. (Black)
I just removed my sticker today, and the sticky adhesive would not come my tv either. I tried alcohol first and to that only worked a little. Then I even tried warm soapy water(thats what sharps customer service told me to do) but that didnt work. So I put a razor scraper inside a rag with soap and water on it and that put little scratches on my new shiny black bezzel which made me very mad. The scratches arent really bad but who wants that on a new tv. FINALLY THE ONLY THING THAT WORKED WAS THE WD-40 NO MESS PEN. YOU RUB THAT ON THE STICKY ADHESIVE THEN WIPE OFF WITH WARM SOAPY WATER, WORKS REALLY WELL ONLY DID IT 2 TIMES. TO BAD I DIDNT DO THAT BEFORE ALL THE SCRATCHES. IF YOU DONT HAVE THE PEN I THINK YOU CAN JUST SPRAY REGULAR WD-40 ONTO A RAG AND WIPE.
Dec 20, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
Hey wiz
Hello!!!
Copy the photos using the memory card reader!!!
Aug 19, 2008 | Vivitar ViviCam 3750 Digital Camera
V3 razor screen is locked
describe ur problem briefly for help!!!!
May 16, 2008 | Motorola Mobility RAZR V3
Repaire scratches on a lcd flat screen
The eraser method is even better than I first thought.
I acquired my first scratch some weeks back, tried the eraser method, and was quite pleased with the results, as my scratch was approx. 80% less visible, a faint grey line visible only on very light or dark coloured backgrounds, instead of the glaring black line it was at first.
Today my monitor toppled again (I really must tether the damn thing to something next time) creating - gulp - a new and even larger scratch. Oh, no... But whodathunk I'd end up happy I got the 2nd scratch? Oddly, I am happy, 'cause I took the opportunity to lay the monitor flat, take my white eraser again , and really go to town rubbing both new & old scratches. Lo & behold, both scratches appear to be now virtually 100% invisible or gone. My 2-scratch monitor is better now than it was as a one scratch one! I'm now convinced it's partly, largely, or completely due to the heat from friction of rubbing the eraser across the scratch, plus pressure applied, that does the trick. The heat must soften the plastic surface making it malleable, and the pressure of rubbing smooths out the jagged scratch edges, making the scratches disappear.
-So, if at first your eraser doesn't completely eliminate your scratch, try, try again! Keep working on it - harder!faster! And with luck, you'll get results like mine: complete elimination of two ugly scratches!
Apr 25, 2008 | Computers & Internet
Scratches on Plasma TV Screen
My daughter scratched my TV Plasma with a Pen - It now has scratches. What can I use to get rid of these scratches.
Mar 26, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
