Question about Kenmore Kitchen Ranges
WE HAVE A KENMORE GAS RANGE ABOUT 10 YEARS OLD.WHEN WE TRY TO USE THE OVEN IT WILL LIGHT BUT NOT COME UP TO TEMP.BROILER WORKS FINE.ON LP GAS.NO IDEA WHERE TO START.DON'T KNOW IF IT IS BURNER OR WHAT.COULD USE SOME INFO.THANK YOU.
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Sep 09, 2010
I have a Kenmore Elite oven. The upper oven doesn't maintain temp setting. Eg, if I set baking temp at 375, oven may get to that temp but a few minutes later, it's at 325 or less. Broiler works fine.
im taking that it,s gas....do you smell gas at anytime? sounds like you migh have a light gas leak if it,s gas...also how old is this oven?
Aug 13, 2016 | Kenmore Ovens
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
I have a GE xl44 Gas stove. Oven will light, but not maintain temp. Broiler works fine. Ideas?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas range converted to LP gas huge flame in oven
was the injectors converted in both and was the regulator converted
Jan 21, 2010 | Kenmore 78530 / 78531 Gas Kitchen Range
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Burners and broiler work, but oven doesn't
If the broiler is working then the element is good. The T-stat controls the oven temp. Have you checked it?
Jul 03, 2009 | GE Spectra JGBP35 Gas Kitchen Range
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Jun 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
48 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
