Question about Gateway 450ROG Notebook
Module light on and computer won't start up - Gateway 450ROG Notebook
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 19, 2010
Won;t start red blinking light is on checked staarter relay and fuse #3 they were good help me please i need my car
Red blinking light , anti-theft system ! Your best bet is take it to the dealer (tow) . This starting system is controlled by a computer , be it a BCM - body control module or the PCM powertrain control module . Very complicated messaging between the BCM an PCM on CCD serial data bus Takes place . You need a factory scan tool to diagnose these type problems .
Nov 15, 2015 | 2008 Dodge Charger
Why won't my 2003 cadillac cts start with the new theft deterrent module?
there is one wyre you can cut coming from the computer check itrenet taht will disable antitheft everything else will work properly that will let you no if it is the anti theft
Mar 30, 2013 | Cars & Trucks
My 2008 bmw 5 series won't start, when you insert key the ignition light won't come up. The last time it started the key sign came up with a line across the key say this is the last time the c
hmm your car has a problem with theft sistem or one of your theft modules is going out or wireing problem most likely some how you activeated your theft sistem only the dealer can help you on that they have to erase code and reprogram it othereby me saying modules i mean them antena on your colom your key or the theft module hope this helps im a auto repair mechanic no shop can help you ok
Nov 17, 2012 | BMW Cars & Trucks
2002 saturn sl won't start, turn over but won't start
Done cars have a kill switch if they are low on oil. Check your oil. If the oil is good, it may be the ignition switch.
Jan 01, 2018 | 2002 Saturn Sl
06 trailblazer trouble with anti theft system, I think, starts right up then other times the anti theft light comes on and it won't start. can try it 2-4 hours later and it starts right up????
The first thing to do get it checked for DTC'S - diagnostic trouble codes . Not at auto zone or any other parts store , you want to have full scan of all the modules on the car. Don't know how much you know about automotive electronics , computer controlled systems etc.... Your vehicle has at least 10 modules (computers ) on board , there all talk to each other on a serial data network . C.A.N - controller area network . Or in the case of GM it has it's own . GMLAN -
How to Diagnose Controller Area Network CAN When you turn that ignition switch to start it is an input to the computer ,be it the PCM or BCM ..
Jul 01, 2017 | 2004 Chevrolet TrailBlazer
Washer won't start. Power is on, pressed power, then pressed permanent press, then water temp, then start. There is a red light on spin cycle and it just beeps and doesn't start.
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
My 1998 jeep cheorkee engine turns but won't crank, could it be the computer or what?
it's highly unlikely, there are only two things that can make this happen, not getting fuel (fuel pump failure, fuel pump regulator) or not getting ignition (bad coils, ignition module failure, bad distributor, distributor cap, rotor)
Jun 24, 2011 | 1998 Jeep Cherokee
The Orange light on an HP dx2000 mt is on and the computer won't start up.
Please check your cable on your hard drive to make sure it is pluged in? and also check your ram
memory modules ? I hope this helps!
Jun 03, 2011 | HP Compaq dx2000 Microtower PC Desktop
95 town car won't start
When the 1995 Towncar turns over but won't start or there is no spark you need to look to see if the O/D light is on once you turn the key on. If that light is on the Power control module has rec'd a code from the transmission that there is a O/D fault and the car won't start until that light is off. If you unhook your battery, red post first and neg next and wait at least 10 mins. and reattach the posts neg first and then the red post next the computer will reset and the light will turn off and the car will usually start. If not repeat the procedure. This is an O/D button or O/D switch problem when the light is on.
Feb 02, 2011 | 1995 Lincoln Town Car
Gateway 450ROG Notebook Logo
185 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
