Question about Samsung MW5592W Microwave Oven
Samsung MR5491G display prompts to touch a keypad function, but nothing happens with any punched button. The display = "2 Touch a functrion key..." etc This display was self generated. It was set to display the time-of-day. When I looked at it a day ago, it displayed "2222". After reset power I got the above display. Keypad seems to be locked out. I have had this unit start cooking all by itself.
MicrowaveSvc
  • 9098 Answers
SOURCE: Operational failure
Your keypad or control board may have moisture or grease on them, but your keypad (membrane switch) is likely going bad. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find a keypad (if available) by entering your exact model here: http://www.samsungparts.com/search/search.asp
Posted on Sep 22, 2007
SOURCE: Samsung Over range Microwave
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
Posted on Jan 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Samsung MW1080STA Microwave Oven
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You can order Samsung parts here.
You can find your nearest Samsung-authorized service center here.
To find out if yours was recalled, please call Samsung's Service Division at 800-932-3837.
Posted on Nov 21, 2008
I have the same "SE" problem. After reading this thread here, I realise it's likely the keypad problem, which explains the microwave's behaviour (no key was working).
So there were two possibilities. (1)keypad failure and (2) bad connection.
Obviously the easiest thing I could start with is to clean the connection. So I first take the cover off. Behind the keypad is a circuit board. In addition to a few connections between the circuit board and other parts of the microwave, there is a ribbon connecting the keypad to the circuit board.
Loose the plastic on the connection, pull the ribbon out from the socket. I then used spirit to clean the exposed copper connections. Put every thing back to place.
Voila, it's working again and we have been living happily ever after.....
Posted on Apr 17, 2009
  • 574 Answers
SOURCE: I have LG over the range microwave and the keypad
Its just a problem with that button on the touch pad, gonna have to take panel off and check the connections could be a burnt wire or broke wire.
Posted on Sep 03, 2009
The top quick access buttons stopped working 2 days ago. The bottom buttons still work but, we can't punch in a custom time. The only thing that will work is the 1 for 1 minute 2 for 2 minute...etc.
One of two things is happening, either you have broken connections in the membrane switches of the keypad and should replace the keypad(which is most likely) or your main control board has failed in a way that it can no longer read signals sent by the keypad.
Aug 04, 2013 | Microwave Ovens
Hotpoint microwave key pad parcially not working
The pads actually share some of the same lines inside the touch pad. There are silver oxide traces inside there. If a trace inside breaks, it depends on which trace breaks as to what pads dont work. If a trace that is common to say pads 1,3,5,7 you would lose function of those pads. 1.....2.....3.....4......5....... it is sort of set up like that inside wher eone connects to another and so on. So lets say a line between 2 and 3 breaks then you would lose pads 3, 4, 5 and any others on that same line. Will have to replace touch pad, cannot repair.
Oct 15, 2017 | Hotpoint JE740WY/GY Microwave Oven
I have a samsung microwave in our motorome. the power is on and I get the "Samsung 50 simple" indicator. However there is no response to the touchpad. The owner's manual says...
You have a bad keypad if you cant get it to respond at all.its also possible the door is not latched properly but usually the clock will set with the door open or closed so I doubt that is the issue
The display is actually saying "Samsung So Simple".
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 10, 2011 | Samsung Microwave Ovens
I touch the touch pad and nothing happens
Hi!!
Try unplugging unit from the wall outlet for 5 min. If the key pad still do not respond, it may have become defective they are not fixable. Replacing the key pad it is often more expensive then buying a new unit.
Spills and directly spraying cleaner solutions into keypad will eventually cause it to fail.
The correct way to clean the front of your microwave is to apply a small amount of the cleaner solution to a cleaning cloth and then wipe the keypad clean
Show your appreciation with a 4 THUMBS Rating for answering your FREE question. Thank you for using FixYa
Oct 03, 2010 | Samsung MT1088SB 1000 Watts Convection /...
F2 E0 "Stuck key" ????????????
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!^!^
Jan 03, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Keypad on microwave wont work
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed...
POWER FAILURE &FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 —Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 —Microwave Relay Failure: Check the microwave relay.
F7 —Microcomputer Board Failure: Change the microcomputer board.
Oct 18, 2007 | Microwave Ovens
Samsung MW5592W Microwave Oven Logo
211 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
