Question about Archos 604 Digital Media Player
Can I charge archos 604 batteries using dvr station and power outlet?
    Problem Solver:
  • 7 Answers
Yes you can, however the battery must be inserted into the 604. Simply dock the 604, ensure the dvr is turned on and the 604 will automatically turn on and start charging.
Posted on Oct 01, 2010
I need a manual to operate the remote control for the Archos DVR Station for 604, 504& 404. Thank you.
user manual:
http://www.archos.com/support/download/manuals/user_manual_dvr_station_imt_v1.pdf
connection sheet (USA):
http://www.archos.com/support/download/manuals/connection_guide_usa_dvr_station_imt_v1.pdf
connection sheet (Europe):
http://www.archos.com/support/download/manuals/connection_guide_euro_dvr_station_imt_v1.pdf
Aug 18, 2010 | Archos DVR Station MP3 Player
Lines across tv when using archos with dvr station, fine when not using on tv
SOunds like a problem with the connection between the dvr station and the tv. Ensure all connections are insered fully and dust free. Also ensure that you have set the output signal to PAL if using in Europe - do this via the setup menu
Aug 08, 2010 | Archos 604 Digital Media Player
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Apr 09, 2010 | Archos 604 Digital Media Player
My Archos 604 wifi only play a few minutes after charging.. I have used the dvr, usb and wall charger and nothing helps.. is my battery kaput? also since messing with it the touchscreen isn't working......
it must be the battery..While charging is pilot lamp lightning ?
To verify,just plug the USB cable to see if device battery charging circuit is working..Device should work normally..
If it does,either your battery is dead or its charger needs to be changed.
Kazim
Sep 13, 2009 | Archos 604 WiFi Digital Media Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Archos 604 will not restart
i had this problem recently when charging on the DVR docking station, i switched it off, took the battery off, left it for a shirt time then pressed the reset, it took a few attempts but eventually it restarted
Aug 09, 2008 | Archos 604 Digital Media Player
Archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Mar 24, 2008 | Archos 604 Digital Media Player
How to record from DVR station
hi there, it should be easy, if your wanting to record off the tv/dvd or video you need to plug (lets say your using phono leads,the ends with red,white,yellow on them) into the output on the video (or what ever the device) the on the docking station plug them into input. then on the archos go to the videocorder n away you go. hope this has help`d
Feb 23, 2008 | Archos 604 Digital Media Player
Archos
does it have a battery? remove it
does it have a reset?
Dec 10, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Open Questions:
See all Archos 604 Digital Media Player Questions
Archos 604 Digital Media Player Logo
99 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
