Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Error 8 -- Has anyone ever taken apart the grinder in an Jura Capresso E8 to clean it? I have had my E8 apart a few times to clean it, but I am hesitant to take apart the grinder for fear it may have some trick to it. Is the first (top) screw reverse thread? I have tried to unscrew it but I don't want to over torque it and snap something.
I am also experiencing error 8. This a great coffee maker but after several years of use following the normal cleaning instructions just isn't enough. I can hear the machine straining after making a cup. I want to clean all parts inside, I got the front off and can lift the top a little. However there are what looks like 4 rivets on the back 2 at the top and 2 at the bottom. I cannot see how to get the top off and am afraid of breaking it.
Do you have any instructions on how to do this? Or can you tell me how to get the top off?
Posted on Sep 27, 2010
  • Tony Karavidas
    Tony Karavidas Jan 22, 2011
    Not only was my machine straining, but it was leaking around the spout area. I managed to take it apart about as much as you did (didn't figure out the rear rivet area).
    I was able to remove the silver logo plastic area in front, and that revealed two more screws which I undid and was then able to remove the spout and the the magnetic slide restraint. (cool design). I found the spout has a black plastic insert which needs to be removed by releasing the four catches and pulling up. There was all sorts of coffee gunk which plugged the spout so badly, it overflowed into the machine. I got that all cleaned up nicely, and the machine works great now!!
  • mike67244 Feb 20, 2011
    Hi Guys,
    A few days ago I opened up my E8. It was easy... the "rivets" you are both concerened about are actually screws! They just look like rivets. Use a good pair of pliers or such and grab them and rotate counter clockwise. I am replacing mine with new screws (for easier work next time). I have 19, 700 brew cycles on mine
  • 4 Answers
The E8 actually comes apart pretty easily. The slightly oval 'rivet' looking things are actually just screws. They can be easily removed with a vise-grip or pliers. You will also have to remove some torx screws, so you will need to have a torx wrench on hand (actually 2 different sizes).
The E8 error is simply coffee grounds clogging up the mechanism. Once you have the covers off, it is still a bit difficult to get at everything but it should be enough. Simply leaving it open and allowing it to dry out thouroughly seems to work in itself. I have actually just run a hairdryer in there to dry out the hard to reach grounds.
However, I recommend plugging the unit in and watching it run through some rinse cycles. Use a flashlight to see, and then follow through with a dry cloth and get as much gound coffee out as possible.
The other symptom which can easily be fixed when you have the machine apart is when water/coffee is pouring out above the intended release, i.e., not out of the spout. This happens just from being dirty and clogged and is super simple to fix and very satisfying! The front grey, plastic, sliding cover pops off and exposes all the residual coffee gunk that is giving you trouble. Just take it apart carefully and clean and your machine will be as good as new.
Once you take it apart once, you will see it is not that difficult and you'll be happy:) We open it up about every 6-8 months now just to clean it. Trust me, when you see what builds up in there, you will want to also.
Or you could send it away and spend $300-$500 for an upgrade. The worst part of that is being without your coffee machine for a few weeks.
OF COURSE....be very careful when it is plugged in. Electricity kills :)
I compare all of this in difficulty to......well, my wife can do it. So can my 10 yr old son. Probably if you can put together a piece of IKEA furniture and you know what a torx is, you can do this.
Posted on Jun 23, 2012
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
Grind time is short, puck is wet and sloppy, espresso weak
Sounds like you might have more than one problem.
From page 12 of the manual... NOTE THE LAST LINE.
"8. ADJUSTING THE GRINDER
• Open the lid of the bean container.
• While the grinder is running turn the grind selector switch to
the desired position (Fig. 6).
-The smaller the dots, the finer the grind.
-The bigger the dots, the coarser the grind.
Important:
The grinding grade can only be adjusted while
the grinder is actually grinding."
Sep 08, 2014 | Jura Capresso Impressa E8 Espresso/Coffee...
E8 capresso grinder
My name is Mike. I thought I would help you. I have attached a Complete manual for your machine with trouble shooting tips and solutions. Please if you can rate my help and some kind words would be nice.
http://www.uk.jura.com/home_uk_x/service_support/download_manual_jura_impressa_e80_e85_english.pdf
Also here is the link to my personal site to contact me and view all my areas of expertize for future help. I hope you visit me some time.
http://beta.fixya.com/users/mc1bean
Thanks so much, Mike
Aug 09, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso E8 keeps getting error code 8 over and over. I will clean, remove grounds etc, it will make a few espressos, then back to the error code. I can hear it struggling.
One of the problems that I see with these units is the Grinder setting. Sometimes the grinder is set too fine for Dark and Oily beans. This setting will ( can) clog up the brew screen after less than 10 cups are brewed. Also, running the cleaning tablets through to create a clean starting point may help you. Try turning the grinder to a slightly coarser setting and try that.
Sep 21, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Makes grinding noise then Malfunction 8
Jura Capresso E8 Makes a cup of espresso then makes a gear grinding sound and then throughs an Error * on the screen. Machine was repaired by Capresso a year ago.
Oct 27, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
My dispay on my jura E8 says error 5.
Simple fix - got the machine serviced, needed a new thermoblock apparently, could also have been one of the couple of sensors they replaced. Total cost including box, bits and carriage - £180 plus change.
Expensive but now I have it back, it all seems worth it!
Nov 30, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Fault 8
simply (not really), needs to be taken apart and thoroughly cleaned. If your not technically saavy and lacking tools, send it in...
Sep 06, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura capresso E8
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Apr 10, 2008 | Jura Capresso C1000 Espresso & Coffee...
Mulfuction 8
for my E8 it meant block water flow - i had installed filter improperly. took it out, power down/up, error cleared.
Anyone located a service manual for Capresso's?
Jan 24, 2008 | Jura Capresso Impressa S90 Espresso...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
1,124 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
