Question about Ricoh Aficio 180 Laser Printer
I have a Savin 9945dpe copy/printer that is receiving the functional error message: SC401-02. This message began after I changed a toner cartridge and vacumed the machine. Is there something I can do to possibly fix this myself?
  • mapzone110 Sep 09, 2010
    yeah, i thought i screwed something up doing the vac job.
    President:
  • 2,777 Answers
Oh wow, I bet it occurred when you vacuumed the machine. You never want to run a vacuum inside of electronics due to all the static energy it creates. You need a very special kind of vacuum to do that. The only thing you can try is to turn off the machine with the power button, then to unplug it for a good 2 minutes. Then replug in the machine and try firing it up. Hopefully it will reset whatever was tripped inside by the static electricity. If it still has the error message you need to contact Savin to find out about a repair at:
1-800-524-1801 or just visit their website here and find an authorized person to help you:
http://www.savin.com/global/DealerLocator.aspx
Posted on Sep 09, 2010
I replaced the tone cartridge in my Savin 2400WD copier, but the light still indicates that I need to change the toner cartridge. What do I do?
I hate to say it but switching it off at the wall waiting a minute and then back on sometimes resets its little brain.
I trust the toner cartridge is all correct for this model.
May 13, 2015 | Savin Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
Savin 9945DPE cannot Network print
Did you format the new drive through the service mode on the copier? As long as the drive is compatible then it should work once you format it.
Jan 03, 2010 | Office Equipment & Supplies
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
Printer not printing at all
Though there was no message to indicate toner issues, I changed the cartridge anyway. That must have been the problem. It works now. The old cartridge was 3 years old and, though barely used, may have outlived its quality. Thanks for writing back.
Aug 11, 2008 | HP OfficeJet 4215 All-In-One InkJet...
My Canon MP730 MFC won't print. Ink cartridges are all full. Error message / alarm says " Check printer, press resume key" and has #336 also in message box rotating. I have tried reinstalling...
Save ink cartridges and toner cartridges
christinarosy
Don't waste money on Printer Ink. Save up to 65% on toner cartridges, ink cartridges and printer supplies. "http://www.concordsupplies.***comhttp://www.concordsupplies.com">http://www.concordsupplies.***com
May 28, 2008 | Office Equipment & Supplies
Add toner message
have you tried another toner cartridge? eyo7 eyoifiok2005@yahoo.com
Mar 30, 2007 | Savin 9935DP Laser Printer
Ricoh Aficio 180 Laser Printer Logo
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
