Question about GE Ovens
My GE profile PCT920 is beeping and the control panel isn't working.
  • 101 Answers
Control board
Posted on Sep 10, 2010
GE profile convection double oven. Model#jkp56w0w1ww 1.The touch panel on the Oven is off and none of the button works. There is not light or code in the display area. 2. The light inside the oven...
Oh, you probably got this fixed already. If it happens again, it helps to take the control panel off, insert paper towel folded up neatly and slotted into the ribbon (it absorbs the moisture which causes the ribbon to short out). Sounds crazy but it's true! I saved our family hundreds of dollars with a piece of paper towel!
Aug 18, 2013 | GE Ovens
Built in double oven GE profile
F7 code is 'shorted matrix or start key' could be due to a problem with the key panel or control.
Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
On a GE Profile Performance oven the code F7 show up on the key pad and the oven Beeps. Hitting the end or stop button stops the beepimg for about 5 minutes. Turning the power off achieves the same...
Hello there
The code can be caused by a faulty keypad or a Stuck keypad which may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel. :
furtrhermore
Jul 21, 2010 | GE Profile JTP56 Electric Double Oven
Control panel continously beeps with message to
Could be a faulty control as you suspect but also may be a bad keypad. If the "start" button has no effect I'm suspecting the keypad first.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | GE Profile JT912 Electric Single Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
I have a GE Profile built in oven and the F7 display with the beeping sound. Clear or cancel will not work What do I do
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Jun 28, 2009 | GE JGRP17 Gas Single Oven
F7 Code on my GE Profile Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
I have a GE Profile JTP18. F7 is shown on the
Hi. this F-7 code is referring to a Shorted Clear/Off Key due to membrane switch, control or connector. unfortunately, this is an integrated control assembly and, the entire control board must be replaced in this case.
Replacing the control(ERC,EOC) will fix this issue.
Jun 16, 2009 | GE Profile JTP18 Electric Single Oven
F7 error
Good Luck!!
Have a nice Day!!
May 03, 2009 | GE Profile JTP18 Electric Single Oven
GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Mar 28, 2009 | GE Profile JT952 Electric Double Oven
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
