Question about Danby (DAR604BLS) Refrigerator
Anything I put into the fridge immediately begins to smell and taste strongly of plastic. I've tried a number of solutions and nothing seems to work. It isn't normal "fridge" taste either, it's so strong that it causes things to become inedible. What can I do to solve this problem?
I don't know, but our new Sub Zero has the same problem and I went online to try to find a solution as well! It's very offputting.
Posted on Sep 13, 2010
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
We have a strong "plastic"
try washing with vinegar solution. it is just the new factory smell and taste.
Feb 03, 2011 | Samsung Refrigerators
Strong plastic smell and taste on a new Keurig Platnum coffee mak
I had the same problem and I discovered that after running 3 resevoirs full of water through the machine at 192 degrees , it got rid of the plastic smell. Set the cup size at the largest size mug and then just open the lid and close it , hit brew and let it fill the cup. Dump the water in the sink and repeat until you go through at least 3 resevoirs. The smell should be gone by then.
Sep 13, 2009 | Keurig B70 Coffee Maker
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Apr 01, 2009 | Refrigerators
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
Oct 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Odor in fridge
Probably getting a new Fridge-mother doesn't want to continue to deal with repairs. Thanks anyway.
Oct 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Danby (DAR604BLS) Refrigerator Logo
82 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
