Question about Microwave Ovens
Is there a way to adjust the volume on the Sunbeam microwave oven model #SGG5702? It sure is loud!
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: sunbeam microwave oven,will not heat,req2uesting code
The manual does not address this code?
Posted on Nov 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Newly Purchased SHARP Microwave Oven
If I had to bet, I would say the high voltage rectifier diode is shorted or the magnetron has failed.
But since it's newly purchased, it will be under warranty and I'd let Sharp fix it free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
  • 1214 Answers
SOURCE: How to operate Electrolux Microwave oven Model EC9055?
Here's the manual -
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0708331.pdf
Posted on Jan 24, 2009
  • 30 Answers
SOURCE: model 721.64282 microwave/convection oven -
No heat but otherwise normal operationA shorted HV diode, magnetron, or certain parts of the HV wiring would probably result in a loud hum from the HV transformer but will likely not blow the main fuse. (However, the HV fuse - not present on most domestic ovens - might blow.)
If the main power fuse is located in the primary of the high voltage transformer rather then at the line input, the clock and touchpad will work but the fuse will blow upon initiating a cook cycle. Or, if the fuse has already blown there will simply be no heating action once the cook cycle is started. There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact. See the section: See the section: Testing the magnetron.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms. See the section: Testing thermal protectors and thermal fuses.
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • Open HV capacitor - see the section: Testing the high voltage capacitor. A shorted HV capacitor would likely immediately blow the fuse.
  • Open HV diode - see the section: Testing the high voltage diode.
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem. See the section: Testing the magnetron.
  • Open winding in HV transformer. See the section: Testing the high voltage transformer.
  • Defective HV relay. A few models use a relay in the actual high voltage circuitry (rather than the primary) to regulate cooking power. This may have dirty or burnt contacts, a defective coil, or bad connections
  • Shorted HV diode - see the section: Testing the high voltage diode.
  • Short or other fault in the magnetron - see the section: Testing the magnetron.
  • Short in certain portions of the HV wiring. See the section: Testing and repairing the wiring and connections.
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
If you are interested in doing it yourself the following link will help : Microwave Repair Manual
(**All the above references to tests are found here)
Posted on Oct 22, 2010
The Microwave dosent heated and its has sound
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Jan 21, 2013 | Sunbeam SGG5702 - 0.7CF Microwave Oven
I have SUNBEAM microwave, model SM0701A7E--how do I set the power to MEDIUM? Thank you.
After a long search and reading I finally got it. To adjust power level follow these instructions:
1. Set timer for amount of minutes you want.
2. Hit "power" button"
3. Change the power from 100% to another percentage by hitting numbers 1-9
4. Press Start
Dec 22, 2010 | Sunbeam Microwave Ovens
My brand new Sunbeam microwave model SGG5701 will not heat. it appears to be working but wont heat food or defrost
Can not find a fuse for a Sunbeam microwave model SGG5701. Where can I find one? My microwave went out after only 3 months of having it.
Aug 15, 2010 | Sunbeam SBM1000 Microwave Oven
Microwave runs, turntable turns, fan runs, but does not heat,
No heat means the magnetron circuit has failed. It is the part that generates the microwaves to heat the food. Usually not worth fixing since the magnetron costs nearly as much as a new oven. To diagnose, if the oven is on, you will hear a loud buzzing sound if the magnetron is shorted.
Jun 30, 2010 | Sunbeam SMW777 Microwave Oven
Sunbeam model 7700w turn dial works with no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
etyety
Sep 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I need to replace my glass plate inside of the
For assistance with your Sunbeam® Microwave, please call 1-866-257-3336.
Jun 03, 2009 | Sunbeam SMW777 Microwave Oven
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need instruction book
Jan 05, 2009 | Sunbeam SBM7500W Microwave Oven
Will not heat
The loud pop was almost certainly the high voltage diode going bad. To find parts, I suggest you call the number on your owner's manual or check with the store where you bought it. Sunbeam may not make this part available, so be prepared. Maybe they have authorized servicers in your area. Ask them about that. Good luck.
Sep 21, 2007 | Sunbeam SMW777 Microwave Oven
Volume control
no there is no way to adjust the alert they come already factory set.good luck
Apr 16, 2007 | Amana ACE208 Convection/Microwave Oven
Microwave Ovens Logo
77 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
