Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Ok this happeneds about everynow and then. i will turn in my tv and i can not see anything but i can here it! now i used to tolorate this because i could just hit guide and it would come back on. since the new guide has came out, that trick does no longer work. got any help?
  • Sony Master
  • 8,457 Answers
The tv now turn on have flicker of picture few sec.than died,have sound left only?Yes,than the 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Posted on Sep 09, 2010
LG 42LC7D turns on ok but no display or sound,tried using monitor out with another tv but no picture either
Check to make sure you have the right input selected for the input that ou have plugged into.
Jan 20, 2013 | LG 42LC7D-UB Television
Hi I need to replace 3 x blown capacitors for my LCD monitor. They are 820uf 25v. Do they have to be an exact match ie ceremic/tolorences?
They can be 1000uf 25v (20% higher value is OK), higher voltage is also OK but it may not fit the board. The temperature rating must be 105c and Low ESR type which is very important for switching power supply. You should replace them in a set.
You can get the PANASONIC FM or FC series from DIGIKEY, or from Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 03, 2010 | Samsung SyncMaster 940N Flat panel Monitor
TV will turn off then turn back on by itself the input shows up at the top when it comes back on. The start up sound does not play when the picture restores. Has happened when watching TV (HDMI) and play...
The first thing to do is disconnect ANYthing that is connected via HDMI and then use the component, composite or s-video inputs and see what happens. If it works ok then most likely what ever is connected to your TV via HDMI is causing the issue (it does happen). The second thing if that doesn't solve the issue is replace the lamp if its getting really dar and has never been done before. If the emmisions of the lamp are low (darker picture) the set thinks the lamp is not on and will force a restart..Please take a moment to rate my answer...Thanks
May 18, 2010 | Samsung HLP5067W Television
Will not turn on
SOUNDS LIKE A POWER SUPPLY OR HORIZONTIAL OUTPUT TRANSISTIOR (HOT) GONE BAD. IF IT IS THE POWER SUPPLY IT WILL MOST LIKELY BE THE CAPACTIORS BLOWN OR OUT OF TOLORENCE.
Feb 21, 2010 | Philips Magnavox 20MS3442 20" TV
Overclocking FAILED
This could be a number of things, memory, video card, communication promblems, I suspect its the voltage droping below the tolorance if it happens every once in a while. I would try plugging into surge proctor first.
Nov 21, 2009 | ASUS Computers & Internet
Electrical problems in 2002 sebring lx sedan
wiring harness short of tracing all the wires with a voltmeter......
Oct 03, 2009 | 2001 Chrysler Town & Country
Tv will shut off while viewing. standby light flashes.
The problem with your Sony. This is a common problem with these Sony sets.
1. How many times does the light blink? Is it consistent and continuous?
2. Does anything happen to the picture itself, or does the set just turn off?
Answer that and I can help you.
Nov 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
