Question about Peg Perego John Deere Gator HPX Ride on Toy
1st and Reverse will not work. 2nd gear will work replace shifter and back tires
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Bad motor, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
  • 9 Answers
SOURCE: Goes in 1st and Reverse but not 2nd
Something you may want to check is to see if there is a "governor" for the 2nd gear. My 4 year old has a 4x4 similiar to this and the only two gears that worked were 1st & reverse until my husband had to unscrew a piece from the 2nd gear setting..check the manual or if you don't have one, look online through the manufacturers website. I hope this helps!
Posted on Feb 17, 2009
  • 19 Answers
SOURCE: !st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Posted on Apr 21, 2009
bradnsarah20
SOURCE: john deer power pull only works in 2nd
I am experiencing the same issue with my sons gator. He was riding it, stopped to look at something, then when he got back in, 1st and reverse no longer worked. I replaced the shifter switch and have the same issue. It was suggested that the switch was reversed, but it only installs one way. I have yet to solve this. Please, if anyone has any better information, please let me know.
Posted on Apr 25, 2009
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
SOURCE: Have a PerPerago John Deere Tractor. The shifter
If it is new, contact Peg Perego for a replacement. If it is not new, you can upgrade the shifter to a better version. (I just upgraded the one on my kids' gator.) You can buy the upgraded shifter for $24. http://tigerimports.net/sunshop/index.php?l=product_detail&p=7095
Posted on Sep 19, 2009
Won't reverse. 1st gear seems to be in neutral position according to shifter.2nd gear in 1st gear position and so on. Shifter is hard to move?
Need more info. What Machine? Was it working fine on your last mow and then just act up when you started to mow again?
Did you look at where the Shift Lever goes to see if it is bent or obstructed?
Oct 06, 2015 | Garden
I just replaced my throw out bearing for my 1999
it sounds like the shifter is not back in the proper spot try taking it out and reassembling it.
Sep 22, 2014 | Cars & Trucks
I have a 91' ford f-150 that I pulled out of a parking lot and shifted from 1st to 2nd and instead of going into second it became stuck in fourth. then I proceeded to pulling the three screws out from...
if there has been no abuse or no chance somethind bent shifting rods under veh. check for loose or worn out shift rod connections,If internal trans shift drum problems your world just got more complacated
Aug 26, 2013 | Cars & Trucks
Gator won't work in 2nd Gear
sounds like you have a bad motor, you'll need to pull the dump bed off to acess the motors and disconnect one and then see if it works
May 22, 2013 | Peg Perego John Deere Gator HPX Ride on...
Speedometer quit and transmission will not work in 3rd or drive but will in 1st and 2nd
i have a 2003 chev s-10 pickup with automatic/ 4 cyl I am not able to move shifter from park to drive i believe my shifter cable is binding
gears selection matches fine when shifting. But will not get out park go to reverse or neutral selection only drive, 3rd, 2nd and 1st
do i need to replace shifting linkage cable?
Oct 01, 2012 | 1996 Chevrolet C1500
2nd gear won't work
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath
Oct 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
!st gear won't work
Hope this helps
Apr 18, 2009 | Peg Perego John Deere Gator HPX Ride on...
Feb 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
