System completely freezing when i use the battery, ihave tried another battery but it was the same, without battery no problems found & it working correctly .
    Problem Solver:
  • 24 Answers
You actually answered your own question.
Make sure the replaced battery is working fine.
Try using your battery on another NB.
If the NB does not freeze that means your motherboard has malfuncitoned. and the battery is working fine.
The trick here is to find whether the battery of the board is the culprit. Try eliminating one by one and you will find the culprit.
Posted on Sep 10, 2010
Two new alternators on and the car still will not charge and it kills alternator. Need to know what to look for in the wiring harness. Auto Zone tested alternators before installation. Still won't...
Go to web site WWW.HMASERVICE.COM and register your vehicle by VIN #. You'll then have access to shop manuals, wiring diagrams, technical service bulletins, illustrations, etc.
Provided there is no problem with the vehicle's wiring, find out what the charging current is to the battery. I've seen batteries which TEST good, but when under a CHARGE short out internally.
Example: Tested a battery & charging system on a Hyundai Elantra, the battery tested "Healthy" but indicated there was a CHARGING SYSTEM PROBLEM. I checked the battery voltage while the engine was running and found the battery voltage at 14.3 VDC (which was normal). I then used a Digital DC Clamp meter arount the positive (+) battery cable & found the battery was charging at 70 Amps!.. it was supposidly already fully charged (should have only been taking 4 to 6 amps when fully charged).
Best guess without looking/diagnosing the vehicle myself
Maybe this will help.
Jun 30, 2011 | Hyundai Elantra Cars & Trucks
How do i reset my mp3 player its just frozen?
How Do I Fix My Sony MP3 Player That Froze & Won't Turn On?
Sony Walkman MP3 players, like most MP3 players, can occasionally freeze up and stop working properly. Fortunately, there are two simple ways of resetting the Walkman system. The first method takes only 10 to 15 seconds to complete and is an effective way to troubleshoot most technical problems you may have with your Walkman. The second method, unfortunately, may take several hours; it requires you to allow the battery to drain completely. Whatever the problem is that's causing your MP3 player to freeze, one or both of these methods should clear it up.
Instructions
Things You'll Need:
* Paperclip
* Walkman MP3 player charger
Reset Button
Straighten the paperclip and set it aside for now.
Locate the reset button on your Sony MP3 player. On most models, it can be found near the volume control mechanism.
Insert the end of the paperclip into the reset button and hold it down for three to five seconds. When the screen flickers, you'll know that the MP3 player's system has been reset.
Remove the paperclip and wait for the system to reboot.
Battery Drain
Turn on your MP3 player.
Let the battery's life deplete. Since the system is frozen and no music is being played, this will take longer than usual.
Check that the battery is completely depleted. Sometimes the screen just goes dark during this process, but the battery is not actually drained. You can check this by pushing buttons or trying to power up the system.
Connect your MP3 player to its charger and plug it in to a power source. Allow the MP3 player to fully recharge.
Power on the MP3 player. The system should be operating normally again.
Jan 10, 2011 | Sony NWZE345 MP3 Player
Have an Acer Aspire 5920-6470 that is dead. The power supply seems OK with the green light on and ~19 VDC on the DVM when checked. no power light on computer when plugged in, with or without battery. ...
Try remove the battery and unplug it from the AC. Hold down the power button for 35-45secs. plug AC back and see if you can power it back on. If not, the motherboard is shot.
Dec 29, 2010 | Acer Aspire 5920-6727 Notebook
Hello, I have a problem with my widescreen. I have a laptop (HP Pavilion dv2418ca, Windows Vista, Memory 2,00 GB, Processor Intel (R) Core (TM) Duo CPU, 32-bit Operating System) and my widescreen...
It may be caused by overheating. Overheating is the main problem with HP portables. Use a fan to cool down the computer and check how long it last working. If blowing air with a fan "Appears to fix the problem" stop using the computer and get maintenance service for it. The processor area needs to be cleaned.
Nov 23, 2010 | HP Pavilion dv4-1120us Notebook
Hi! My Dell D610 doesn't charge the battery. When I plug the charger without a batt, the system powers on but the batt doesn't get charged when attached. Help me solve this problem pls.
1. Install and update the system BIOS:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=LAT_PNT_PM_D610&os=WW1&osl=en&catid=&impid=
Note: Make sure that both the ac adapter and the battery are attached to the notebook. Follow on-screen instructions on how to flash the BIOS.
2. If Dell QuickSet is installed, press <Fn><F3> to display the QuickSet Battery Meter. The Battery Meter displays status, battery health, charge level, and charge completion time for the battery in your computer. If battery health says that the battery is degraded and needs replacement, then you may need to replace your battery.
Nov 12, 2010 | Dell Latitude D610 Notebook
Panasonic CF-30: While plugged into a/c the
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
For me, it looks like the Canon LiDE 100 USB powered flat scanner was drawing extra power than your laptop's power adapter could handle properly. As time passes, this might have caused some damage to either the system, the A/C adapter or both. Rightnow, your laptop's adapter's output might be no longer capable of supplying enough power to charge the battery & operate the laptop simultaneously. Please try a replacement adapter & check if it resolves your problem.
Dec 28, 2009 | Panasonic Toughbook CF-30 Notebook
I cant install new version of my anti virus
you need to install deep freeze again. After installing, restart the computer and uninstall it.
hope this will help!
Peace!!!
Dec 26, 2009 | Computers & Internet
I had a GPU issue so i searched in google to find a solution and i found a solution it was needs to open the laptop , the motherboard the GPU problem solved now but there's a new problem that i didn't have...
I would check to make sure the AC adaptor connection on the motherboard was not damaged when you opened the pc. ( I have done that a few times.) I'm uncertain of what you have done to solve the problem. Since you have the new battery, again try to charge the battery. when it show the charge is complete, let the pc run until it goes off, when it does, keep powering your pc on until it will no longer power on. (You want to make sure the battery is completely drainned.) Once complete, try plugging the AC to your pc and monitor the charge. You may need to let the pc charge for at least 2 hours before powering the pc on.
Good Luck
C2Solutions
Aug 17, 2009 | HP Pavilion dv2000 Series Laptop Full...
NOT SPPORTING SOUND & WIRELESS DRIVERS FOR WINDOS XP
why not activation windows XP Home Edition
help me.
May 28, 2009 | Sony Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
