Question about Garden
Switch would like to replace it with same type of switch ..where do i find a switch for wen 14' chain saw ?
  • 3,740 Answers
This is where you need to start. http://wenproducts.com/wensupport.html
They will most likely refer you to a service center but you might luck out and actually find out what the switch part number is. Make sure you have your model number when you contact them. Your model should be 5014 or 6014
Kelly
Posted on Sep 09, 2010
Is there a master link
I personally have never seen a master link in a chain for a chain saw. What are you trying to do?
Jul 29, 2014 | Wen 4014 14-Inch 8 Amp Electric Chain Saw
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Chain for wen 14" chain saw cannot find. Other models fit? Thank you
My best advice is to find a lawn and garden shop that services chain saws. Take the chain you have and they can make one just like it.
Aug 30, 2013 | Remington Electric Chain Saw
Wen electric chain saw
take your bar along and compare If all the holes line up then there will be no problems with any bar that is 14''long
Aug 03, 2013 | Garden
I have a 14 inch WEN/Wagner electric chain saw in good condition with the exception of the trigger switch. I have not been able to find a replacement for that small part. Can you help?
Jim it is so long out of production about the only thing available is the OM. If you can get a pn off the original switch Allied or Newark is an option. Maybe a trigger switch from a saw in current production can be modified to fit.
Different model Poulan electric saws follow:
1. http://www.ordertree.com/modelinfo/PWE/1220-Electric-Saw/75.1220-Electric-Saw.1.59.1.html
2. http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
3. http://www.ordertree.com/modelinfo/PWE/1625-Electric-Saw-Type-2/75.1625-Electric-Saw-Type-2.1.59.1.html
“EL-14“ through “ES400” here (5±):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
A length of spring steel and almost any micro switch might also be an option. Beyond that I am out of ideas.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 22, 2010 | Remington Electric Chain Saw
Need new chain for wen saw 5014
It is here N;
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Select "Wen; 5014; #DriveLinks; All; All; All".
#DriveLinks, the part of the chain that fits in the bar groove. Match the number with the fourth column to get bar length.
The above results are for an original or equivalent bar. Only YOU can determine your level of expertise, how much risk (read the triangular warnings - the OE chain was probably green) you are willing to assume and choose one of part numbers listed. Once you make your choice it can be found on the Internet or through local merchants (no shipping and handling fees). If the local outlet does not handle Oregon your choice can easily be converted to a part number of the manufacturer they do handle. I suggest a few phone calls to save you time and gasoline. Given the Oregon part number and your assurance of a purchase, if my store, your chain would be waiting when you walked in the door.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 02, 2010 | Electric Chainsaw Sharpener
I replaced the chain on the poulan el 14 and when I would tighten the aft bolt this caused the chain to begin to stick when I would manually move the chain
Poulan "1420 Electric Saw Type 2" (may not be your saw)http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
Open the link; Click "View the illustrated parts list [GO]" link; open the "Illustrated Parts Lists" folder; Click "Chain Saw Assembly Type 2". Compare items 20 and 21 with your saw, the flared portion of 20 should be toward the clutch cover not the engine and on the clutch side of the bar. The only other thing that comes to mind is item 23 should fit into the hole on the bar (the bar should be tight against the oiler channel; engine side of the case.). HTH
Lou
If these are correct please add comments below and we will continue.
Dec 29, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Correct replacement chain
take the old chain with you when you go tobuy the new one is the best way
Aug 25, 2009 | Garden
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
